2.3 Engine Swap (Pup) #550888 01/12/05 12:02 AM
mph9111 Offline OP
Got a rod knocking in my '92 and found a '94 with less miles on it to exchange with. The '94 has the fuel injection setup on it.
I want to know if I can simply remove the Fuel Inj. system on the '94 motor and put my carb setup on it? Had my carb redone last year and it is perfect.
Should I consider keeping the FI system? Advantages? Need new CPU/Wiring/high pressure fuel pump?
Regards, mph9111
Re: 2.3 Engine Swap (Pup) [Re: mph9111] #550889 01/12/05 01:22 AM
randii Offline
The motor is pretty much the same under the intake manifold, so you should be able to swap the car stuff onto the efi (and vice versa) on your 2.3.
As you guessed, there is a difference in fuel pressure (and methods --the EFI uses an electric fuel pump and IIRC, the carb uses a mechanical pump). You'd need the appropriate ECU and engine harness, and I'm not sure whether that extends to parts of the body harness (guages and such). I'd suggest just swapping the block and head. You'd probably get a little better mileage with the late-model EFI, but IMHO, it is more trouble than it is worth to upgrade the rest of the truck to match the 94 EFI and intake.
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5848 MB (Peak: 0.6327 MB) Data Comp: Off Server Time: 2026-05-30 01:06:20 UTC
