battery fix #551377 01/12/05 08:53 PM
hunterp Offline OP
ive had a red top for a couple years, i was out wheeling one weekend and the thing slipped off the tray and was resting against the pulley and when i got home i found a 3 three inch long gash ( <img src="/forums/images/graemlins/wink.gif" alt="" /> , heheh) IN THE BATTERY, its about half an inch deep.
obviously this thing is oxidizing or whatever, losing charge so i had to replace it - kirkland style.
can i mend this battery using JB weld or something that wont be eaten by the acid? seems like a shame to toss a $100 dollar battery that has ten more years of life to it?
thanks
85 4runner/duals/detroits f&r/5.29s/winch/stuff
Re: battery fix [Re: hunterp] #551378 01/12/05 09:33 PM
mt_goat Offline
Interesting, was anything leaking out of it?
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: battery fix [Re: hunterp] #551379 01/12/05 10:16 PM
OOP'S Offline
Could get some interesting results if you used JB Weld, it is a metal based product. I would try so type of two-part epoxy, read the lable to see what it can take!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: battery fix [Re: OOP'S] #551380 01/13/05 05:34 AM
hunterp Offline OP
hmph ill give it a try, hopefully it will make a good b*tch battery for my dual setup in the works.
Re: battery fix [Re: hunterp] #551381 01/13/05 09:59 AM
4
4xGeek Offline
IIRC, it's toast once any portion allows air in... <img src="/forums/images/graemlins/frown.gif" alt="" /> But I'd still try the 2-part epoxy idea too. <img src="/forums/images/graemlins/notooth.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6036 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-10-26 13:59:55 UTC
