1" needed in the rear, springs or shackles? #551661 01/13/05 06:20 AM
J94_4runner Offline OP
the rear of my 4runner is sitting about 1" lower than the front. I have 3" AllPro leafs on the front and rear. Allpro said the height difference is b/c the springs were mainly designed for the weight of a truck in mind. so I'd need to get the 4" in the back, and 3" up front ot make it sit level. I'm also running Allpro Shackles that came with my kit. So should i look into some longer shackles or cough up the $220 for 4" allpro springs?
www.celicasupra.com
Re: 1" needed in the rear, springs or shackles? [Re: J94_4runner] #551662 01/13/05 06:35 AM
DirtyHarry Offline
Toyota Moderator
There are a lot of things that you could do before spending more money. How much clearance do you have? Could you pull a leaf out of the front to better match the rear? What about a small lift block? Or, as you suggested, longer shackles. I would be weary of getting them TOO long though, lots of extra leverage and in my experience they tend to bend the spring eye if they are excessive.
Re: 1" needed in the rear, springs or shackles? [Re: DirtyHarry] #551663 01/13/05 07:01 AM
well i like how the front sits, and the rear needs a bit more clearance. So lowering the front is not an option.
www.celicasupra.com
Re: 1" needed in the rear, springs or shackles? [Re: J94_4runner] #551664 01/13/05 07:33 AM
Adam F Offline
Maybe drive it around a little and let the front springs settle in a little, and it might just get lower.
97 4R, stock, daily driver
Re: 1" needed in the rear, springs or shackles? [Re: Adam F] #551665 01/13/05 07:40 AM
they've been in since Dec 15th and i'm driving it daily about 25 miles... and i went wheeling 1 time already. they settled about 1" with time & the Frontrange bumper. I doubt they'll be getting much lower... but they might; i can't tell the future. How long does it take for them to properly settle? b/c my rear springs about 6 months old.
www.celicasupra.com
Re: 1" needed in the rear, springs or shackles? [Re: J94_4runner] #551666 01/13/05 09:54 AM
2
2utadud Offline
what part of the rig did you measure this? mine is tilted to one side. left is 1" higher than the right. measured it from the fender-fender and tailgate.
Re: 1" needed in the rear, springs or shackles? [Re: 2utadud] #551667 01/13/05 03:14 PM
Put a winch on the front and the extra weight will bring it down level! Seriously, if you were thinking of adding anything to the font like a brush guard or winch, the extra weight will help bring it down.
Re: 1" needed in the rear, springs or shackles? [Re: J94_4runner] #551668 01/13/05 03:18 PM
ZUK Offline
J94----you would be a good candidate for a coil in the center to lift and add payload ability.....
mostly stock
Re: 1" needed in the rear, springs or shackles? [Re: ZUK] #551669 01/13/05 03:45 PM
well i currently have a Front Range front bumper(65lbs?), and custom rear bumper(100lbs). I want to add a Milemarker E9000 winch to the front, and i also plan on either buying a new rear bumper that is lighter or fabing a lighter one up myself. so... maybe with a winch upfront , and a lighter bumper in the rear it'll level out <img src="/forums/images/graemlins/drunk.gif" alt="" /> i guess i'll live with the measley 1" difference for now.
www.celicasupra.com
Re: 1" needed in the rear, springs or shackles? [Re: J94_4runner] #551670 01/13/05 04:12 PM
Red_Chili Offline
Toyota Section Staffer
Good plan, I doubt your front springs are done settling, as well. Good info though.
-Bill
PHP: 7.4.33 Page Time: 0.005s Queries: 16 (0.004s) Memory: 0.6370 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-05-29 17:16:25 UTC
