Re: Most popular engine swap?
#551763
01/15/05 03:40 PM
I have a 88 Toyota SAS that i just got done swaping out the 4.3 i had in it with a 350 and the SM465 w/NP208. The only problem that i had was finding someone to make me a custom power steering hose (high pressure side)! Other that that it went pretty smooth. Good luck with the swap! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: swamp_man]
#551764
01/15/05 10:49 PM
I was up in the air on what motor to run and what setup. When it comes dowm to it the decision was based on what I found for sale at a decent price. Some of the prices around here have been just a little on the highside for my likings. ie One guy had a 700r and tc and he wanted $1,200cdn. I got the whole rolling chais and drive train for $700, pays to be patient.
#551765
01/16/05 06:18 AM
you got a heck of a deal on that. i wish i could find that down here for that that price i would buy the whole thing that way i could swap out my axles and everything. Good luck with it. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
#551766
01/18/05 03:11 PM
Foyoto, More info on your 5.0 swap please! I was thinking that same engine just because it is about 100 pounds lighter than the 350. Did you have to relocate the radiator? I know the 5.0 is a little longer than the chevy motor. Any details you could provide would be great! Thanks!
#551767
01/18/05 10:18 PM
have done the 7m swap - very easy ,AND easy on the bank account as the parts needed are in most wrecking yards . 200 smooth hp and sounds great revved up. Should not destroy a w series tranny/case . Lots of time wrenching but that is good fun - skinner
#551768
01/22/05 06:20 PM
Foyoto, More info on your 5.0 swap please! I was thinking that same engine just because it is about 100 pounds lighter than the 350. Did you have to relocate the radiator? I know the 5.0 is a little longer than the chevy motor. Any details you could provide would be great! Thanks! Sorry it took me so long to respond. The radiator is in the stock location. I used a 3 row V6 with a 2000cfm pusher fan in front of it. No room for a mechanical Fan. So far no cooling problems at all. I had to do some sheet metal releiving behind the exhaust manifolds for clearance. If I do this again I think I'll try the 5.0 or 5.7 chevy TBI with 4L60E and see how it fits. The only problem I have is that in overdrive the spud shaft in the adapter seems to chatter when I let off the gas or am coasting. Bill <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6068 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-07-14 21:47:02 UTCValid HTML 5 and Valid CSS
