Lost 20 pounds.(of rust) #551968 01/14/05 12:25 AM
OKRED Offline OP
I have the body off my truck and I am in the process of creating a rust free frame. Let me tell you guys this thing is bad, most people would have chosen a different route at this point. This frame is pretty much gone from the front leaf mount all the way back, but the gas tank is perfect go figure.
Any way I lost at least 18 pounds in crap and rust so far and I haven't even started cutting. I have gotten the mid rails between the wheels done. I have a trip to the steel dist tomorrow, this is crappy work. <img src="/forums/images/graemlins/baby.gif" alt="" />
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Lost 20 pounds.(of rust) [Re: OKRED] #551969 01/14/05 04:01 AM
javven Offline
And here I am with my factory black-waxed frame looking perfect, whining because I have to replace a cat (meow).
Hehe. Luck, bro.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Lost 20 pounds.(of rust) [Re: OKRED] #551970 01/14/05 05:46 AM
Careful now, frame woes is what led me to...
And...
All told, I went through a gallon and a half of POR-15. Everything underneath was done in basic black. <img src="/forums/images/graemlins/smile.gif" alt="" />
And then the turbo, but you've already got that covered. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Lost 20 pounds.(of rust) [Re: MontyMcV] #551971 01/14/05 07:05 AM
OKRED Offline OP
That's where I need to be.
Is that an extra frame I see off to the right??
Re: Lost 20 pounds.(of rust) [Re: OKRED] #551972 01/14/05 07:35 AM
Very good eye. <img src="/forums/images/graemlins/lol.gif" alt="" />
To the right is/was my bad frame. Rather than deal with it, I used the one from my second donor truck. For, being as I had never done anything like this, it was nice having the bad one largely intact while I reassambled the good one.
BTW, thew yard/drive was long ago cleaned up. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Also, here was my little gizmo for doing inside the cross-tubes and other similar tight spots. It's a dish mop with the handle cut off and then glued into a drilled broomstick.
Re: Lost 20 pounds.(of rust) [Re: MontyMcV] #551973 01/14/05 08:53 AM
StockRaider Offline
You guys cleaning and painting the underside of the body as well? Frame restoration intrigues me, only thing that keeps me is that I only have 1 garage and 0 experiance. Then again my frame is not in too bad of shape (surface rust only)
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Lost 20 pounds.(of rust) [Re: StockRaider] #551974 01/14/05 01:07 PM
OKRED Offline OP
Yeah I remember now all the talk of swabbing POR 15..
Re: Lost 20 pounds.(of rust) [Re: StockRaider] #551975 01/14/05 03:47 PM
...I only have 1 garage and 0 experiance...
That was me one year ago! Still only have one garage, but a little experience now. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Lost 20 pounds.(of rust) [Re: OKRED] #551976 01/14/05 11:19 PM
W
wyleone Offline
If it had that much rust scale on it, was it worth salvaging? Just asking. If you spent the time removing all that rust, wouldn't the inside of the rails have it too.
Re: Lost 20 pounds.(of rust) [Re: MontyMcV] #551977 01/14/05 11:22 PM
powerRam50 Offline
nice pics montymcv
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6382 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-17 12:00:31 UTC
