Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552427 01/15/05 03:13 AM
speeedracer Offline
Scott your puttin too much thought and effort into this little problem. I would already be done and be workin on the next problem. Go plan B and the thing will break free and pop right out. <img src="/forums/images/graemlins/notooth.gif" alt="" />
88 red shortbed 5" superlift, 35 BFG M/T, 5.29's, detroit r, welded f, LCE EFI pro power package, electric fan, battery in bed, owned since new, 73,000 miles now.
2003 Dodge Ram Hemi 1500 Q/C 4x4, 315 A/T BFG's
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552428 01/15/05 05:14 AM
1
1FastSS Offline
Mine got stuck once. Use plan B. That's what I did. It came right out after it pulled the truck about a foot. Wrap a tow chain around it, hook it up to a bigger vehicle, and pull. That way it will only slide your vehicle if it doesn't come out. Get a little slack in the chain and go....make sure you wrap a blanket or tie a rope to the chain and truck to keep it from flying when it comes out. It will come out or you'll be jerking your truck around the block. Have someone in the truck pushing on the brake also. You will need to do it on concrete, not dirt or gravel also......Do it......and be done....Good luck....
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: How do I remove a rusted 2" trailer receiver? [Re: 1FastSS] #552429 01/15/05 05:18 AM
OOP'S Offline
If you are going to do this, do not wrap it around the ball, they have been known to break and go through windows, knock people out or kill them!!! Take the ball off and use a shackle, at least then you are working with a double shear!!!! <img src="/forums/images/graemlins/mrt.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: How do I remove a rusted 2" trailer receiver? [Re: OOP'S] #552430 01/17/05 04:26 AM
ScottFW Offline OP
Well I managed to get it done yesterday. I actually went with Plan A... insert a piece of 2" square tube from the back side and beat the blue hot hell out of it with a sledge. My main reason for going this route is I don't have a tow chain, just a recovery strap that I thought would be too elastic to work well. I stopped by Pacific Industrial Supply and got a 12" length of 2" square tube for a whopping $3. It took about 30 minutes of hammering to get it out. Today I cleaned everything up with some files, wire wheel & some naval jelly, tomorrow will repaint, GREASE IT UP, and reassemble. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552431 01/17/05 06:25 PM
ChrisH Offline
I have some pictures of what gives first on my PC at home. I'll post 'em up after work
- me and a buddy were out wheeling and found a dead Vdub Rabbit at the top of a mtn. Decided to pull it around some heh heh <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552432 01/17/05 07:18 PM
ACES_HI Offline
Ive personally tried plan B using a BF tree but was smart enough to quit before I busted something. Dang receivers still stuck in there to this day. <img src="/forums/images/graemlins/angry.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: How do I remove a rusted 2" trailer receiver? [Re: ACES_HI] #552433 01/18/05 08:00 PM
ChrisH Offline
Oops.
PHP: 7.4.33 Page Time: 0.048s Queries: 16 (0.041s) Memory: 0.6275 MB (Peak: 0.7351 MB) Data Comp: Off Server Time: 2026-11-04 20:00:07 UTC
