Wanted: part numbers for heater blower and fan resistor... #553581 01/17/05 04:27 PM
uzombie Offline OP
I'm sorry that I could find the numbers. I buried my T100 books and docs somewhere in my office and wondered if anyone has the info handy?
I need the part number for the blower (to replace the noisy fan) for a 1995 Extracab 5zve T100 (man). And if there is a part number for the fan-blower resistor...I think mine is needing replacement.
from a previous thread, I understand its pretty easy to take out, just remove the glovebox and a few screws...?
Re: Wanted: part numbers for heater blower and fan resistor... [Re: uzombie] #553582 01/17/05 06:42 PM
NYT100 Offline
Uzombie, I replaced my noisy fan blower with a new motor sub-assembly last spring. I found the box that the new one came in with the part number- 87103-42020
This is the motor and circular fan. It was very easy to replace on my 97 with only a few bolts holding it in.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
Re: Wanted: part numbers for heater blower and fan resistor... [Re: NYT100] #553583 01/17/05 07:07 PM
uzombie Offline OP
THANK YOU!
Re: Wanted: part numbers for heater blower and fan resistor... [Re: uzombie] #553584 01/18/05 08:23 PM
harliv Offline
Did anyone every come up with an affordable fix for the resistor pack? Last I checked the dealer wanted an arm and both legs for it. I've been living with off, low, and highest for some time now and I'd love to get the mid choice back.
Re: Wanted: part numbers for heater blower and fan resistor... [Re: harliv] #553585 01/19/05 03:43 PM
banshee4785 Offline
I also had to replace this last spring. Just thought I'd add that I didn't have to remove the glove box. You just have to really get down there and look at the couple bolts/screws and it pops right off. For any others that have a problem with their fan with it just quiting/ check the following---with mine the conectors were jus tburned up, so I spliced a few in and poped it all back in and that was that,
peace
95 4x4 ext cAB t100-
Re: Wanted: part numbers for heater blower and fan resistor... [Re: harliv] #553586 01/21/05 09:02 AM
kewlynx Offline
Junkyard for resistor blowers. I should break out the meter sometime and get readings if 4Crawler hasn't already done it.
**ubi apis- ibi salus**
Re: Wanted: part numbers for heater blower and fan resistor... [Re: harliv] #553587 01/21/05 09:02 AM
kewlynx Offline
Junkyard for blower resistors. I should break out the meter sometime and get readings if 4Crawler hasn't already done it.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6179 MB (Peak: 0.6920 MB) Data Comp: Off Server Time: 2026-10-22 12:14:03 UTC
