Page 2 of 4 1 2 3 4
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: LRJ4x4] #553944 01/18/05 08:38 PM
CapnCrunch Offline
I'll post a ratio comparison chart this afternoon when I get the chance.
Basically, 33's would be the mo-bettah way to go with a 4-banger IMHO. Your RPM's would be higher than you are now w/31's and 4.625 diffs. 35's and 5.29's would have you doing a little lower RPM's than you are now with your 31's.
I might still consider 35's (but doubtful), though, because I have the 2.85 t-case gearing. Will suck worse on the highway, but should be fine on the trail.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: LRJ4x4] #553945 01/18/05 09:37 PM
L
Lee N Offline
Going from 235-75R15's and 4.625 to 33's and 5.29's you would be turning just about the same RPMs for the same road speed. So, these would return you to the same overall gearing as stock. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: Lloyd Swartz] #553946 01/18/05 10:29 PM
LandRaider Offline
Awesome Frank!!! Glad to hear that another options is readily available!!!!
That is a breakthrough indead, and a requirement for 35s. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Once again Lloyd.... this is not necessarily true. There are SEVERAL ways to deal with this. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: LandRaider] #553947 01/19/05 01:40 AM
cragdweller Offline
When I ordered my set from Aki almost a year ago, he said at the time that my set and his set (8" front) were produced after the order. I was surprised that Mitsubishi Japan actually had their gear producer cut two sets for Aki and I. Apparently, they will be even more willing to make gears for Frank, who will probably be selling many sets. My gears are still sitting under the bench. My truck hasn't been running for several months now, so I wasn't too worried about installing them right away. Especially now that I may replace the pickup with a V6 SWB. Too bad I didn't wait until now to buy them, could've saved a little money... Oh well, at the time, I thought I was getting one of the last sets in existance! Good luck with your venture, Frank! I may have to order another set down the road...
I think I will be running a 34" tire with mine. I would like to leave myself with a slight gearing advantage over stock, to compensate for increased weight and rolling resistance. A 295/75R16 or a 265/85R16 should be about right depending on how wide will fit. I'll be trying to minimize body lift by trimming fenders and perfecting the backspacing.
1994 3.0L 4x4 pickup.
4.62 gears (4.22 stock), 33x10.5 BFG MTs. LSD rear. Five speed trans. 172K
Previously owned Mitsubishis:
1986 2.6L 4x4 Mighty Max, 1985 2.6L 4x4 D50
1987 2.6L Raider, 1989 3.0L Raider
1995 Montero SR
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: cragdweller] #553948 01/19/05 01:55 AM
CapnCrunch Offline
For those curious, go to
http://www.fivethirty.com/misc/gears-tires-rpm-mph-conversions.xls
and download or run the spreadsheet I've put together. Keep in mind that I'm not an expert on this, this info is just what was passed on to me. <img src="/forums/images/graemlins/baby.gif" alt="" />
For those without the ability to run Excel spreadsheets:
(transmission X diff X t-case X 336 X MPH) / Tires (inches) = RPM
Transmission gears
First: 3.918
Second: 2.261
Third: 1.395
Fourth: 1.000
Fifth: 0.829
Reverse: 3.925
Diff gears
4.625
4.88
5.29
T-case gears
1.925
2.850
1.000 (to get RPM for 2WD or 4-HI)
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: CapnCrunch] #553949 01/19/05 02:04 AM
LRJ4x4 Offline
Did a little google work <img src="/forums/images/graemlins/kewl.gif" alt="" />
Calculator
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: CapnCrunch] #553950 01/19/05 02:09 AM
LRJ4x4 Offline
So with 5.29's 33's and a 5spd your looking at 3100 RPM's to run 70mph <img src="/forums/images/graemlins/kewl.gif" alt="" />. Somthing to think about when I get a stronger engine or Turbo.
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: LRJ4x4] #553951 01/19/05 02:35 AM
CapnCrunch Offline
I didn't see an equation which factored-in that you'd be doing that while shooting video. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: CapnCrunch] #553952 01/19/05 03:06 AM
stony-man Offline
Am I reading that correctly? NOT available for a GenII 3.0 manual transmission?
Re: 5.29 Supply Breakthrough !!!!!!!! [Re: stony-man] #553953 01/19/05 05:47 AM
DougH Offline
Mitsubishi Forum Moderator
I dont think they are available for any of the high pinion 8 inch front axles. That would be all genII's with either a 3.5 or a 3.0 manual.
DougH
1995 SR - RIP
1993 RS - RIP
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.013s) Memory: 0.6466 MB (Peak: 0.7726 MB) Data Comp: Off Server Time: 2026-11-17 11:29:00 UTC
