radiator tab came unwelded #554173 01/18/05 07:31 PM
one of the top tabs on my radiator came lose from the unit so its shakin around a bit now. I've heard this is not a quick weld fix. What can I do to secure it again without having to pull the whole unit?
thanks
JG
Re: radiator tab came unwelded #554174 01/18/05 07:37 PM
Take it to a radiator shop and have them Braze it back on. If the affected piece doesn't touch the tank or core, it should be a quick cheap fix.
Re: radiator tab came unwelded #554175 01/18/05 07:50 PM
foxtrapper Offline
Loosen the top radiator mounting bolts, squeeze them together, retighten. That's what I did on my radiator that has had both sides come off. It's held quite nicely for a year now.
'97 T-100 SR5
Re: radiator tab came unwelded #554176 01/18/05 08:04 PM
ok thats what I'm looking for...cheap quick fix... wasnt sure if they needed to pull the radiator or someother expensive process to get that tab mounted back on...Braze
thanks
JG
Re: radiator tab came unwelded #554177 01/18/05 08:12 PM
Brian894X4 Offline
Mine did the same thing, but what I did was use a bunch of RTV sealent to hold it together. A friend suggested it and at first I thought he was crazy, but it's worked incredibly well and I didn't have to remove the radiator.
JB Weld might work also, although I'm not sure how that would affect the thin metal of the radiator.
Re: radiator tab came unwelded #554178 01/18/05 11:05 PM
Esquire812 Offline
Wirebrush or sand the area clean, get out your non-electrical solder and the propane torch and reattach it. Thats how I've fixed mine in the past. Even been so lucky as to have the original factory solder glob melt and not have to use any new. Quick to fix, easy and as long as you keep the heat off the cores you will be fine.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: radiator tab came unwelded [Re: Esquire812] #554179 01/19/05 04:09 AM
Hecubus Offline
ditto
just cleaned mine up and heated it up with the propane torch, some solder and better than new never had a problem again.
Jed <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
Re: radiator tab came unwelded [Re: Brian894X4] #554180 01/19/05 04:10 AM
BeaterToyota Offline
It works great. Mine's been held together with JB Weld for over a year now.
Jason
'88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
Re: radiator tab came unwelded [Re: BeaterToyota] #554181 01/19/05 05:52 AM
swamp_man Offline
also you can go to a boating store and purchase marinetex it better then jb weld in my opinion.
Re: radiator tab came unwelded [Re: BeaterToyota] #554182 01/20/05 11:27 PM
awesome, I wasnt sure if JB weld was up to the task..Think I'll get a price on the fix at a shop then probably go buy the weld..haha
JG
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6278 MB (Peak: 0.7336 MB) Data Comp: Off Server Time: 2026-07-14 23:58:31 UTC
