Page 1 of 5 1 2 3 4 5
Foggy Windows #554185 01/18/05 07:44 PM
marcre Offline OP
I don't know if I actually have a problem or not, but something is not right.
The last few days while driving my windows will go from nice and clear to covered in fog. The car is warmed up when it happens and it is instant. I mean it is bad, I had to pull over today because I could not see at all. It has been real cold lately(around 5? F) My friend in the car said this is a sign something has stopped working. The lever for fresh/recycled air is on fresh.
Anyone point me in a direction to look. My blower was making a god awful noise today as well, but air was comming out. It was hot as well.
I must reitterate, the change from nice clear windows is instant and it is thick fog on the window. Hopefully it is the cold air playing tricks on me but I have never experienced anything like this.
TIA
Marc
99 rodeo 4x4 v6 80,000 miles
My Rodeo
Re: Foggy Windows [Re: marcre] #554186 01/18/05 08:07 PM
BigSwede Offline
Usually that means your heater core is leaking...the moisture from the coolant is what is fogging up your windows. <img src="/forums/images/graemlins/frown.gif" alt="" />
Serenity now!
Re: Foggy Windows [Re: BigSwede] #554187 01/18/05 08:16 PM
marcre Offline OP
That is what I was afraid of. How do I check it. Would it leak onto the floor of my front passenger seat? That happened to my 91 MR2 several years ago and there was a smell and a wet floor on the passengers side.
My Rodeo
Re: Foggy Windows [Re: marcre] #554188 01/18/05 08:20 PM
W
Wayne Offline
More likely on the floor. If you're real lucky the fresh/recycle air isn't working. (You flip it, but it's broke).
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Foggy Windows [Re: Wayne] #554189 01/18/05 08:33 PM
marcre Offline OP
I don't think it is the lever(fresh/recycle) because I can hear the noise it makes upon a switch. Plus there is a difference in air when it is in the recycle mode as opposed to the fresh mode.
I just went ouside and checked the floor and it is dry, but it is real cold out and I did not want to be out there too long. I will have to go check again after I put on more layers of clothing(-10? wind chill).
This is probably an expensive fix isn't it(if it is the heater core).
My Rodeo
Re: Foggy Windows [Re: marcre] #554190 01/18/05 10:04 PM
Bigpoppax2 Offline
No it's really cheap, just a piece of tubing and a couple of hose clamps. Oh, you'll probably be all spoiled and want heat.
Yeah if it's the heater core and you want heat it will be a bit pricey. That's the one part I've seen for Isuzu's that's just rediculously overpriced.
Joe
Re: Foggy Windows [Re: marcre] #554191 01/19/05 02:14 AM
Z
zKnightWhoSaysNi Offline
If you got a leak, you should be able to smell the coolant also.
Try running the A/C (if u have it) at the same as the heated defrost. It will reduce the humidity especially with the fresh air setting.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: Foggy Windows [Re: zKnightWhoSaysNi] #554192 01/19/05 04:23 AM
BigSwede Offline
Spoken like a true California boy <img src="/forums/images/graemlins/pfft.gif" alt="" /> ...at +5 degrees F there isn't any moisture in the air to speak of, the dewpoint is well below freezing. So there has to be an internal source of moisture...the only source in the passenger compartment in winter is the heater core...or heavy breathing <img src="/forums/images/graemlins/zombie.gif" alt="" />
Serenity now!
Re: Foggy Windows [Re: BigSwede] #554193 01/19/05 04:25 AM
marcre Offline OP
Unfortunately it was not heavy breathing <img src="/forums/images/graemlins/lol.gif" alt="" />
My Rodeo
Re: Foggy Windows [Re: marcre] #554194 01/19/05 05:42 AM
W
Wayne Offline
How about UNDER the car?
Leaks, not heavy breathing.
Where the hoses meet the firewall, or where the A/C condensor drains?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6428 MB (Peak: 0.7681 MB) Data Comp: Off Server Time: 2026-05-30 01:15:16 UTC
