Removal of Dash Piece on 1st Gen Rodeo
#554596
01/19/05 05:11 PM
Located in the center of the dash, just right of the instrument pod, there is an approx. 2"x5" cover that I would like to remove. Does anyone know if this just pops out or if it is mechanically fastened from underneath somehow. I looked in the manual and can't find even what might have been an option in here. Thanks for any help.
George <img src="/forums/images/graemlins/nana.gif" alt="" /> 92 Rodeo XS 4x4 HomePage
Re: Removal of Dash Piece on 1st Gen Rodeo
[Re: RodeoXS]
#554597
01/19/05 06:04 PM
I believe it just pops off - take a smallish/thinnish screwdriver and just pry gently. Or forcefully depending on your usual method of automotive repair technique. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: RodeoXS]
#554598
01/19/05 07:12 PM
There's a post recently about the availability of a factory clock in this location.
IIRC, it clips in with built-in plastic spring-back fingers that have a little barb on their tips for retention. IIRC, I used a thin, broad, stiff tool to lever this panel out.
Randii
[Re: randii]
#554599
01/19/05 08:24 PM
Thanks guys. I was thinking it just popped off but didn't want to break it in case I want to put it back. I also was thinking about the clock feature but the radio has one so it didn't make sense to have two.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6024 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-07-14 12:26:44 UTCValid HTML 5 and Valid CSS
