87 Trooper II Engine Swap
#555453
01/21/05 05:09 AM
I have a 1987 Isuzu Trooper II, with a rebuilt 4 cylinder 2.3L engine. I'm doing research to determine what engine I can swap with my current. I would like to swap my 2.3L a bigger engine with more horsepower and more torque. But I'm not sure what engines I can swap, with few or no major modifactions needed. I know that I can use a 4 cylinder 2.6L, but I wasn't sure if that would be a worth wild swap or not. I've also looked at the 89 6 cylinder 2.8L, but was unsure if they could be switched out. Thanks.
Re: 87 Trooper II Engine Swap
#555454
01/21/05 05:44 AM
Do you have a Automatic Transmission by chance? If so, and its a four speed (30-80le/AW4/A340H) there is a number of engines that can be swapped.
#555455
01/21/05 05:45 AM
No, I have a five speed manual.
#555456
01/21/05 06:27 AM
With a manual transmission the only engine that is direct bolt on from the 2.3L engine is the 2.6L engine. Now if you want to change transmission and build some custom motor mounts, just about any thing is possible. Of course though, it will $$$.
#555457
01/23/05 07:32 AM
Do you have a Automatic Transmission by chance? If so, and its a four speed (30-80le/AW4/A340H) there is a number of engines that can be swapped. If I understand you correctly , the 2.3 auto has many swap options, could this be the same for the 2.6? I have an 89 automatic with a 2.6 , what are the options for swap outs for me?
#555458
01/23/05 07:30 PM
Do you have a Automatic Transmission by chance? If so, and its a four speed (30-80le/AW4/A340H) there is a number of engines that can be swapped. If I understand you correctly , the 2.3 auto has many swap options, could this be the same for the 2.6? I have an 89 automatic with a 2.6 , what are the options for swap outs for me? http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.5956 MB (Peak: 0.6638 MB) Data Comp: Off Server Time: 2026-07-14 05:23:29 UTCValid HTML 5 and Valid CSS
