coninuous cranking when I turn the key? #556272 01/22/05 09:12 PM
hubsj Offline OP
Looking into a problem that seems to be getting worse. Often while starting my truck, it seems as if the starter continues to crank and the engine isnt getting turned. There is an awful grinding noise, similar to that sound it makes when someone tries to start their car twice... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
SO if you have a suggestion for search or ways to solve the problem, i would appreciate it.
thanks
88 4runner 22re 5spd 30x9.5 bfg AT
daily driver - weekly off roader.
284,400= Jasper - hello 5th gear!
true Thorley Header - V6 3rd
Valid inspection sticker (289,000)
Re: coninuous cranking when I turn the key? [Re: hubsj] #556273 01/22/05 09:24 PM
4Crawler Offline
If you mean the starter is not engaging the flywheel to turn the engine over, you might pull the starter and have a look at it.
#1 Make sure it is fully bolted in place, I have heard of starters held in w/ only one bolt or with loose bolts that do this.
#2. Check the condition of the bendix gear, make sure it is not worn out or packed full of grease and dirt.
#3 Check the condition of the copper contacts inside the starter solenoid. If worn unevenly, these can case the solenoid plunger to cock in the bore of the solenoid and get stuck before fully depressing the bendix gear to engage the flywheel: http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Re: coninuous cranking when I turn the key? [Re: 4Crawler] #556274 01/22/05 09:30 PM
hubsj Offline OP
Thanks... I guess I should have just checked your site. Duh. Well adding it to my favorites now.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5958 MB (Peak: 0.6499 MB) Data Comp: Off Server Time: 2026-11-02 12:30:21 UTC
