Idle wondering about GM 60? V6 #556299 01/22/05 10:49 PM
Tom_G Offline OP
I wonder if the 3.6L engine from the 2004 Cadillac CTS or SRX would fit in place of the stock 2.8L? Of course you'd have to find one with a good ECM in a junkyard or something, but check out the specs:
3.6L Displacement
Completely new design
RWD in CTS
RWD or AWD in SRX
Aluminum Engine Block & Cylinder Heads
Four Cam Phasing
Full chain drive valvetrain system
Aluminum Pistons With Floating Wrist Pins & Oil-Jet Capability
Forged Steel Crankshaft
Sinter-Forged Connecting Rods
Structural Aluminum Oil Pan with Steel Baffles different from FWD version
Dual-Stage Variable Aluminum Intake Manifold
Advanced Sequential Port Fuel Injection
Electronic Throttle Control with Integrated Cruise Control
Coil on Plug Ignition
Engine-Mounted Micro-Hybrid Engine Control Module
Optimized Exhaust Manifolds with Closed-Coupled Catalytic Converters
Fully Isolated Composite Camshaft Covers
Outstanding Noise, Vibration and Harshness Control
Horsepower 255 (Cadillac CTS only) <img src="/forums/images/graemlins/smile.gif" alt="" />
Horsepower 260 (Cadillac SRX only) <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Torque 252
<img src="/forums/images/graemlins/mrt.gif" alt="" />
Compression 10.2:1
I saw this on www.60degreev6.com and it just got me thinkin'...
Re: Idle wondering about GM 60? V6 [Re: Tom_G] #556300 01/22/05 11:04 PM
Ed Mc Offline
Tom, since it's part of the 60 deg V6 family, you'd surmise that it should have the same bellhousing bolt pattern.
So, theoretically it's a possibility.
There may be any number of things that would preclude you stuffing it into a Trooper. However, you could make some inquiries at the 60degreeV6.com site and I bet some of the Guru's there could give a definitive answer.
They really get into the nitty gritty of it over there, just about the most in-depth site for 60 Deg GM V6 Fanatics that I've seen!
Cheers.............ed <img src="/forums/images/graemlins/kewl.gif" alt="" />
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5892 MB (Peak: 0.6397 MB) Data Comp: Off Server Time: 2026-07-15 00:21:34 UTC
