Brake warning light #557317 01/25/05 01:46 AM
shovelhead Offline OP
I've got an '03 taco 4X4 TRD 3.4, The temp has been around Zero and I've been getting a brake warning light when it goes below 5* F. According to the owners manual only two things will turn on this light, the parking brake is on or the brake fluid is low. Neither of these conditons is present. Has anyone else experienced this problem? <img src="/forums/images/graemlins/confused.gif" alt="" />
With enough time and enough money ya can fix anything
Re: Brake warning light [Re: shovelhead] #557318 01/25/05 03:11 AM
I get this a lot when it's really cold out. I found that it comes on and off every now and then with no consistancy. I believe that it has to do with the sensor on the e-brake lever itself freezing. I drive a couple of feet and coast in neutral to see it my brake is actually on or not. If it's on I pull the brake lever once and it frees the brakes up and releases. Sometimes my e-brake does freeze though so make sure it's released before you drive all over the place. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brake warning light #557319 01/27/05 02:45 AM
I only get it when I step on the brake and after about 5or6 miles it goes out <img src="/forums/images/graemlins/confused.gif" alt="" />( I don't use the parking brake as per the owners manual [Auto])
Re: Brake warning light [Re: shovelhead] #557320 01/28/05 01:42 AM
Mine sticks on when its been parked over night and its below 0 out, but after a few feet the light goes out and thats it, til the next morning.
Re: Brake warning light #557321 01/28/05 02:21 AM
Obviously you guys idea of cold and my idea of cold is 2 different things since one of you is from Ak. and the other from Me. and me being from balmy N.J. LOL, thanks for the replys, I guess I'll ride it out and see what happens <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Brake warning light [Re: shovelhead] #557322 01/28/05 02:30 AM
LOL, you mean that it isnt between 0 to 20 below F every morning there in NJ?? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Brake warning light [Re: shovelhead] #557323 02/02/05 01:28 AM
Apparently when the brake fluid level is in the normal operating range but low it will turn on this light in the cold weather <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> so it was a simple fix duh
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6117 MB (Peak: 0.6848 MB) Data Comp: Off Server Time: 2026-10-24 02:37:32 UTC
