Winch Rating #557460 01/25/05 06:30 AM
I have a Warn Trans4mer brush guard winch setup. A friend of mine has a 12,000 lb warn winch that he is wanting to get rid of. My plate says it can take up to a 9,000 lb winch, why only that much? Will his winch fit on my plate. Why will this or won't this work? Thanks for any info on this subject.
-Sam
Re: Winch Rating #557461 02/06/05 10:08 PM
NJ_dup1 Offline
Im new to tacos, but I would assume its 9k for one or both of these reasons:
1) The mounting point (transformer mount) is only rated at 9k due to the build, and design, its just not rated for a 12k pull
2) the 12k warn is a larger winch in itself and wont fit in
Nate Johnson
1993 Isuzu Rodeo 4wd - Not Much Crap
1998 Chevy Silverado 2500 - A little More Crap
2006 Suzuki Z400 - A Bit More Than A Little More Crap
2004 Yamaha Raptor 660 - Lots of Crap
Re: Winch Rating [Re: NJ_dup1] #557462 02/08/05 06:29 PM
I figured thats what it meant but I wanted to make sure it wasn't just a recomendation. Like the speed your recomended to go around a corner at or the size tire your supposed to use... Heck with recomendations <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Winch Rating #557463 02/08/05 08:44 PM
Red_Chili Offline
Toyota Section Staffer
Yeah, heck with recommendations... but it will pull that winch mount clean off your truck, man. POINK! <img src="/forums/images/graemlins/oink.gif" alt="" />
-Bill
Re: Winch Rating [Re: Red_Chili] #557464 02/08/05 10:55 PM
Turns out he thinks that winch is made of solid gold or something.... Sounds like its for the best though. Oh well <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Winch Rating #557465 02/09/05 04:59 PM
Red_Chili Offline
You might look at the Warn Magnum line if you are on a budget. Chinese, but they look not to be too bad.
-Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6711 MB) Data Comp: Off Server Time: 2026-07-09 15:11:55 UTC
