Can I lift my IFS 4X4 on a budget? #557523 01/25/05 08:02 AM
dailyDriver Offline OP
I'm thinking about transformin' my daily-driver with a little lift to fit bigger rubber, maybe 2-3". Now I'm running 31" ATs on stock suspension. Its a '94 and cursed with an independent front end. Is there a way to get it on 33's without breaking the bank?
DailyDriver: '94 Xcab 4x4, 22RE, 139K miles, STOCK
Re: Can I lift my IFS 4X4 on a budget? [Re: dailyDriver] #557524 01/25/05 08:33 AM
4Crawler Offline
I have some ideas and links on my web page:
http://www.4Crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
It is fairly easy and inexpensive to fit 33s on an IFS truck. Of course by the time you add in the cost of gears and other items, it is more, but getting the tires to fit is not bad.
Re: Can I lift my IFS 4X4 on a budget? [Re: 4Crawler] #557525 01/25/05 02:48 PM
CraShYota Offline
2" body lift for about 150 - 200 bucks. that would be your cheapest and easyest lift option. Otherwise you gonna get to a 300 to 500 dollar range if you want more travel. you can do the ifs lift for prolly 250 if you know how to make stuff and can weld.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Can I lift my IFS 4X4 on a budget? [Re: dailyDriver] #557526 01/25/05 02:52 PM
I fit my 33x12.5 tires with a 2" lift pretty easily. The real way to go is suspension but for the price you can't beat a body lift. Check ebay I have seen many go from 75-100$$$.
Re: Can I lift my IFS 4X4 on a budget? #557527 01/25/05 03:29 PM
ChrisH Offline
I got my 3" BL off ebay for 60 bucks shipped. It's a Warn body lift, "black diamond" or w/e they have, and it came with all of the steering extension parts, radiator drop brackets, bumper brackets and everything.
Then the $119.00 from sdori.com for my ball joint spacers, 8 bucks shipped for a 1" steel block (ebay again), and $45 for a set of 4crawlers shackles. Roger also sells a much better quality body lift which, had I realized prior, I would have bought.
That's $232, call it 250 bucks (after hardware, pb blaster, band-aids) and I clear 34x10.50's and can't get them to rub.
-I tried a set of 35x10.50 TSL's on and they did rub in the rear after some flexing. The IFS doesn't flex so they didn't rub up front. <img src="/forums/images/graemlins/shiner.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> -Chris
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Can I lift my IFS 4X4 on a budget? [Re: dailyDriver] #557528 01/26/05 01:59 AM
TheBandit Offline
You can find suspension lifts used for pretty cheap. Keep your eyes peeled for people doing solid axle swaps.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: Can I lift my IFS 4X4 on a budget? [Re: TheBandit] #557529 01/26/05 02:22 AM
Scerb Offline
I think a 3" body trailmaster kit runs ~$80 at your local autparts store. That'll be more than enough to clear 33's, especially if you get offset rims.
-Scerb
Re: Can I lift my IFS 4X4 on a budget? [Re: dailyDriver] #557530 01/26/05 03:03 AM
Brian894X4 Offline
Here's what I ran years ago to clear 33s;
http://www.brian894x4.com/33INCHTIRES.html
However, if I ever get another IFS torsion bar truck, what I would do today, is run a set of 33x10.5-15 tires on stock offset rims, install rear extended shackles, and add 1.5" upper A-arm ball joint spacers.
That's the most minimal, but effective lift to clear 33s, gives a real increase in wheel travel, unlike bodylifts and it would look good, in my opinion.
Hmmm, maybe I should buy another IFS truck. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Can I lift my IFS 4X4 on a budget? [Re: Brian894X4] #557531 01/26/05 06:59 AM
willzrunna96 Offline
you can get a 3 inch Trail master body lift for 90 bucks from autozone. its comes with front bumper brackets and steering extension. or goto NTWonline and get a super lift suspension lift for 569 i believe 4wheelparts just started carring budget suspension lifts also for toyotas
Re: Can I lift my IFS 4X4 on a budget? [Re: willzrunna96] #557532 01/26/05 07:17 AM
Hecubus Offline
Get a body lift from www.4crawler.com he's got my vote,
good stuff, great to work with and good prices.
Jed <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.013s) Memory: 0.6405 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-11-18 03:39:58 UTC
