starting the SOA project ..need rear driveshaft advice #557906 01/26/05 12:01 AM
TX4wl Offline OP
Ok I really don't want to drop 300 for a Tom Woods C/V style rear shaft
My question is what are my alternatives... this is a trail rig that will be SOA front with 1/4 eliptic rear moved back about 8" (YJ)
Re: starting the SOA project ..need rear driveshaft advice [Re: TX4wl] #557907 01/26/05 12:24 AM
BigJim Offline
Dallas spend the bucks! Find out eggszackly what you need and spend the bucks!
Re: starting the SOA project ..need rear driveshaft advice [Re: BigJim] #557908 01/26/05 12:32 AM
TX4wl Offline OP
I have been told and have seen people use an XJ front shaft and have a drivline shop fix it up.. just wanted soem thoughts from you guys..it seems to work well but then again why does tom woods charge an arm and a leg for his??.... just want to do it correctly but sometimes researching what others have done saves alotta $$ <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: starting the SOA project ..need rear driveshaft advice [Re: TX4wl] #557909 01/26/05 12:36 AM
There's absolutely nothing wrong with having a driveshaft shop cut down an already existing shaft to the dimensions you need. I would suggest a front shaft from any pre-2003 (or whatever year they went to independent rear suspension) Ford Explorer. They have a fairly large diameter, thick wall tube and a CV joint at the transfer case end. You'll need the proper Torx bit to remove it at the junkyard.
I use these on my CJ's and cut them down myself.
Tom's prices aren't any higher than anyone else's for a new shaft. They are all new parts and the DOM tubing used is not cheap.
Re: starting the SOA project ..need rear driveshaft advice #557910 01/26/05 12:50 AM
TX4wl Offline OP
how much do these run in the yard ... and have you seen this set up on a YJ ...one more thing to consider the rear will be moved back about 6-8"
Re: starting the SOA project ..need rear driveshaft advice [Re: TX4wl] #557911 01/26/05 01:58 AM
i too have heard of the use of a XJ front shaft cut to length. it sounds very doable, and i have had a driveline shortened by my local shop for 40$. if you can find a good shaft i think a 40$ experiment offsets the cost of a 300$ shaft.
Re: starting the SOA project ..need rear driveshaft advice #557912 01/26/05 03:33 AM
RockJock Offline
I hope those XJ front shafts are better than a YJ's
RockJock <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: starting the SOA project ..need rear driveshaft advice [Re: RockJock] #557913 01/26/05 05:43 AM
the early XJ shafts are flimsy straws, along the same lines as the YJ's. the latter XJ shafts were upgraded to a much more robust design in the early-mid 90's, when they front axle when from disconnect to non disconnet. i have one laying in the back yard if you would like a picture.
Re: starting the SOA project ..need rear driveshaft advice #557914 01/26/05 05:44 AM
TX4wl Offline OP
please show me a pic <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: starting the SOA project ..need rear driveshaft advice [Re: TX4wl] #557915 01/26/05 06:01 AM
here you go. if you look you can see the factory balancing weight by the CV joint.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6311 MB (Peak: 0.7379 MB) Data Comp: Off Server Time: 2026-05-29 23:44:41 UTC
