Steering wheel moving countercolckwise(solved) #50431 03/26/03 03:37 AM
Kajo Offline OP
Over the past couple of weeks my steering has been moving counterclockwise. While driving strait my Steering Wheel is approximately 90 degrees from where it used to be. It has been a gradual move and didn't happen all at once. I have all-pro's Hi-steer and nothing is loose in the steering and all bolts and nuts are tight. When I turn the wheel there is little to no slop throughout.
I am assuming my front Skyjacker springs are settling and causing this. Does this sound probable or is there another possible cause.
<small>[ March 28, 2003, 08:16 AM: Message edited by: Kajo4x4toy ]</small>
Re: Steering wheel moving countercolckwise(solved) #50432 03/26/03 02:26 PM
missouriman Offline
I would start checking things. mark your steering arm and make sure that it is not moving on the shaft.
That just seems a bit to far to me.
I am getting ready to do the high steer. How do you like it?
Re: Steering wheel moving countercolckwise(solved) #50433 03/26/03 03:13 PM
Kajo Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by missouriman:
<strong>I would start checking things. mark your steering arm and make sure that it is not moving on the shaft.
I am getting ready to do the high steer. How do you like it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I love my highsteer, I drive my truck 35 miles a day and have had no problems with it except for the box ripping off the frame at the GWNF. Definetely beef up the inside of your frame.
Everything is tight and the arm has not moved on the shaft. I marked it when I put it on. My jam nuts on my tie rod and drag link are marked and have not moved. The only thing I didn't measure was actual height gained when I put it on but the front seems to be sitting at least 1 1/2" lower than before.
Re: Steering wheel moving countercolckwise(solved) #50434 03/26/03 03:51 PM
fourwd1 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Kajo4x4toy:
<strong>I am assuming my front Skyjacker springs are settling and causing this. Does this sound probable or is there another possible cause.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Sounds likely to me. Has any play developed in the steering, that wasn't there before? If so, could be the steering box. It should have adjustment to compensate for wear.
Let us know if you find anything.
Broderick
<small>[ March 26, 2003, 09:52 AM: Message edited by: fourwd1 ]</small>
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Steering wheel moving countercolckwise(solved) #50435 03/26/03 04:03 PM
missouriman Offline
I was going to go with alpro's and use there frame mount kit and back up plate as well.
Or do you mean that I will need additional bracing beyond that?
Re: Steering wheel moving countercolckwise(solved) #50436 03/26/03 04:51 PM
4Crawler Offline
<strong>Everything is tight and the arm has not moved on the shaft. I marked it when I put it on. My jam nuts on my tie rod and drag link are marked and have not moved. The only thing I didn't measure was actual height gained when I put it on but the front seems to be sitting at least 1 1/2" lower than before.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Is this due tot he spring settling? If so, your drag link angle has changed due to the settling. When it goes from a steep to a shallow angle, it gets "longer" so to speak and this pushes against the pitman arm, so its as if you are turning the wheel to the left (CCW) to maintain a straight ahead direction of travel. You may simply need to re-adjust the drag link length to compensate for the change in ride height.
Note: This is the same thing that causes bump steer, hit bump, compress springs, drag link lengthens and causes a slight, momentary steering change.
And ditto on the reinforced steering box
<small>[ March 26, 2003, 11:10 AM: Message edited by: 4Crawler ]</small>
Re: Steering wheel moving countercolckwise(solved) #50437 03/26/03 04:58 PM
Kajo Offline OP
missouriman- I didn't have the backing plate when the box came loose. Since I nstaled it I have had no problems. No additional bracing should be required.
Roger- That is what I am thinking. If I have time this weekend I am going to re-center my box and re-adjust the draglink.
Broderick- There is little to no play at all in the steering system.
Re: Steering wheel moving countercolckwise(solved) #50438 03/28/03 02:16 PM
Kajo Offline OP
Broblem Solved-
It had nothing to do with the steeing system!
I went to Lunch with Frank (85Trailtoy) yesterday. We were talking by my 4Runner and noticed my rear drivers side wheel was way forward. My U-bolts had loosened and the spring pin broke. Everytime I backed up the tire was moving forward and everytime I went forward the tire moved backward. There was a 3" difference in movement. I run blocks and the spring was sliding forward and backward on the blocks <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> . I drove home very carefully fixed this problem and the steering wheel is where it used to be.
I thought my spool wander was getting worse but that is fixed now to. I guess I will make sure I retorque these nuts every time I do preventive maintenance.
Re: Steering wheel moving countercolckwise(solved) #50439 03/28/03 03:17 PM
missouriman Offline
oh shoot!!
for stuff like that I don't want to come loose but know that I will be taking apart again I use silicone on the treads, I perfer it over lock tight.
Re: Steering wheel moving countercolckwise(solved) #50440 04/02/03 06:15 AM
fourwd1 Offline
That happened to me years ago, but it was really obvious as I was going down the road almostly sideways cause the rear of the truck was trying to pass me. <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6398 MB (Peak: 0.7456 MB) Data Comp: Off Server Time: 2026-06-07 02:17:59 UTC
