Tranny for Dana44 SOA on Mitsi pajero?s #559085 01/27/05 07:44 AM
hasse Offline OP
Hello!
If you are going too put a Dana44 "diff on passanger side" under your Pajero/Montero/Raider you can take the gear/tranny from a Mazda B2600 whitch is bolt on to the 2,6 engine.
Hasse
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: hasse] #559086 01/27/05 04:57 PM
LandRaider Offline
Nice info, but even if you can do this, why would you want to??
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: LandRaider] #559087 01/27/05 09:54 PM
Jim_B Offline
Hasse,
Can you not find Dana 44s with the differential on the driver's side in Sweden? They're pretty common in the U.S., but I'm guessing not so common in Europe... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: Jim_B] #559088 01/27/05 10:08 PM
lordtrunks Offline
This is good info for folks that wanna swap in toyota axles this way you could keep the mitsu rear if you wanted to put a 5.29 in it and also have matching 5.29 in the toyo axle upfront.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: lordtrunks] #559089 01/27/05 11:09 PM
sparkem Offline
What kind of t-case does it have? What low range gears? I am getting an axle from a friend for my rear, but his front is pass side. If I could get both from him, it would be easier, because they both are already built, 5.13 gears and lockers. <img src="/forums/images/graemlins/evil.gif" alt="" /> Do you know if it will bolt to the 3.0, bellhousing swap maybe?
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: Jim_B] #559090 01/28/05 04:20 PM
hasse Offline OP
Hello!
The Dana44 is located at volvo C202 "military" and is pretty common in sweden <img src="/forums/images/graemlins/lol.gif" alt="" />)
Hasse
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: LandRaider] #559091 01/28/05 04:24 PM
hasse Offline OP
In sweden it?s not legal too put in another engine than original in vehicels after -76 "smog test legal" <img src="/forums/images/graemlins/frown.gif" alt="" />
the only way too go is if the car/truck weight is over 2600Kg total.
Hasse
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: Jim_B] #559092 01/28/05 04:26 PM
hasse Offline OP
The volvo C202 has the diff on pass-side, Diff on driver side is not common in europe <img src="/forums/images/graemlins/frown.gif" alt="" />
Hasse
Re: Tranny for Dana44 SOA on Mitsi pajero?s [Re: sparkem] #559093 01/28/05 04:30 PM
hasse Offline OP
If the belhousing match too V6 engine i don?t know.
Gearing can i look for at european market.
Hasse
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6262 MB (Peak: 0.7126 MB) Data Comp: Off Server Time: 2026-11-18 03:43:53 UTC
