Which pins are the timing jumper?
#559237
01/27/05 08:31 PM
I am trying to adjust my timing. My FSM hasn't made the move yet and is 130 miles away.
Where is the timing jumper located on a 95 runner 3vze, and which pins do I jump?
IIRC I am looking for 8 deg before TDC jumped and 12 deg before w/out the jumper.
Thanks for the help guys!!
Anthony
Re: Which pins are the timing jumper?
[Re: wave]
#559238
01/27/05 09:12 PM
[Re: wave]
#559239
01/27/05 10:36 PM
Thanks Roger! So the jumper for the error codes is the same one used when setting the timing? Just making sure I don't screw things up to bad!
Anthony
[Re: wave]
#559240
01/27/05 11:15 PM
I think so, it is on my '85 and also on a '94 that I tested. If you put the jumper in and the timing does not change, then it is eitehr the wrong pins or the TPS IDL-E2 setting is off: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
[Re: wave]
#559241
01/30/05 10:46 PM
That was the one! Thanks Roger!! My timing was at about 2 deg after TDC when I checked it. I set it at 10 deg before TDC. It cranks a little smother and I got close to 16 MPG at 80 w/ two kayaks on the roof. Much better.
Thanks again!
Anthony
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6086 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-11-18 08:54:35 UTCValid HTML 5 and Valid CSS
