Floor jack position for 3" suspension lift #559285 01/27/05 09:45 PM
TCAO Offline OP
Where do you guys position the floor jack for the front of the Tacoma? The user's manual showed the spot, but I need to save them for the floor stands. How is about for the rear?
Re: Floor jack position for 3" suspension lift [Re: TCAO] #559286 01/28/05 12:18 AM
john_luttrell Offline
I used a floor jack in the center of the front cross member for the front and did one side at a time. Then I jacked the rear of the truck and positioned the stands on the frame so the axle can be dropped down to install the blocks. Do one side of the rear axle at a time as well to keep from having to fight the axle back into position.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5881 MB (Peak: 0.6357 MB) Data Comp: Off Server Time: 2026-05-29 19:49:14 UTC
