Heads, valves and a few other questions about 91-94 heads #559741 01/28/05 06:55 PM
JamesW Offline OP
I have to replace the head on my 91 amigo, 2.6L. Are there any differences in a head from 94? valve size, air pump crap, ect. Im going to use the old valves (frim the 91, casting 3 head)since they are only about 30k old.
thanks
james <img src="/forums/images/graemlins/cheers.gif" alt="" />
[url=mailto:corsicas@aol.com]corsicas@aol.com[/url] ,1991 amigo, 3 Bodylift,2.5 supension , 33x12.5 ProComp MT's, Ranch 9000s & steering stab.,Calmini header, 2 1/4 pipes, flowmaster Muffler, K&N drop-in Filter, extended breather hoses,Delta cam, 2core Radiator
Re: Heads, valves and a few other questions about 91-94 heads [Re: JamesW] #559742 01/28/05 08:18 PM
RobG Offline
93+ is a newer casting than 91 (casting numbers go up to about 5 or 6, then start over). 95 is the same as 93,94 but without the ports for the air rail. You'd definitely rather have a 94 head over a 91.
-Rob
EDIT: good to see you still around James, its been a while since i saw your name in a post. welcome back my friend.
Re: Heads, valves and a few other questions about 91-94 heads [Re: JamesW] #559743 01/28/05 08:41 PM
mlclark Offline
Isuzu Moderator
Hi James. It's been a while.
There is also a major difference between 91 and 93-on. The combustion chambers got smaller. It will work, you will get a jump in compression and you most likely will like it.
Good Luck,
Michael
Re: Heads, valves and a few other questions about 91-94 heads [Re: mlclark] #559744 01/28/05 09:44 PM
JamesW Offline OP
So the 1995 head would work also, just with out the air rail? And the valves are the sames size?
Its great to talk with you folks again.
james
Re: Heads, valves and a few other questions about 91-94 heads [Re: JamesW] #559745 03/04/05 11:08 PM
pucci Offline
from cross-referencing aftermarket parts, I will say yes. from 88-97 all 2.6 share part #'s & specs.
I was searching later heads and found one from a 94 Amigo that said 'No AIR tubes'. I have seen underhood shots of a 94 & it had the AIR system, but I wonder if mid-year Isuzu made the change?
2.6 Trooper
2.0 Impulse Turbo
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6047 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-07-14 05:01:36 UTC
