Re-positioning seats rearwards #559961 01/29/05 07:06 AM
Has anyone tried moving the mounts for the seats backwards? I've noticed that Roger Brown used to have a 'seat lift' on the 4crawler site, but i'd like to be able to scoot the entire seat back another 2-3 inches for long trips. (i'm 6.4).
anyone have any luck with this? it's so cold out right now that i gotta do the 'armchair' mechanic thing first... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Re-positioning seats rearwards #559962 01/29/05 10:13 PM
Surf, Every time I get into my runner I have the same thoughts! 6-3 here. Have noticed how much leg room the rear seat passengers have when the front seat is all the way back!!! Why!???
Well I'm going to see if u get any advise. Good luck.
Re: Re-positioning seats rearwards #559963 02/01/05 08:26 PM
Maj Offline
I moved the seat back on both my 2nd and 3rd Gen 4Runners. They both are similar. The seat mounting tabs are riveted AND welded to the seat track. Drilling out the rivets is pretty straightforward, releasing the welds without hosing up the brackets and/or the seat track is the tricky part. On my 2nd Gen I used a chisel and hammer wedged in between the bracket and track to free the tack weld. Lots of trauma to the assembly from all the hammering. On my 3rd Gen I drilled out the welds. The additional drilled hole was used for bolting on the angle iron (actually channeled steel) for repositioning the seat rearward.
If you have basic mechanical skills it is fairly easy to do. Take the seat out (4 bolts) and you will be able to see what is involved.
I don't recommend extending the seat more than 2"s. The shoulder belt starts to become ineffective and the outside mirrors are at their limit of adjustability.
1997 4Runner Limited 4x4, 'lectric locka
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5875 MB (Peak: 0.6399 MB) Data Comp: Off Server Time: 2026-06-07 08:05:18 UTC
