weber carb install 88 raider automatic #560317 01/30/05 01:27 AM
hi , anybody ever install a weber on a 2.6 raider auto? if so whats the trick for installing the kickdown cable? any help would be stupendous
thanks
Re: weber carb install 88 raider automatic #560318 01/30/05 02:59 AM
carnuck Offline
Which trans do you have? 904 or Mitsu auto? One is push and the other is pull IIRC.
Build your truck the head men say, but it must be built in such a way...
Re: weber carb install 88 raider automatic #560319 01/30/05 05:10 AM
lee_raider Offline
Although they claim the cable will fit, I couldn't figure it out! I believe others have made their own bracket to hold the cable. I just went without it for a couple of years.
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: weber carb install 88 raider automatic [Re: carnuck] #560320 01/30/05 01:23 PM
mitsubishi trans
Re: weber carb install 88 raider automatic #560321 01/30/05 04:49 PM
I bought my automatic truck with a Weber already on it. The previous owner had fabricated a bracket to hold the end of the cable and it bolted on to the carb somewhere. Find some way to do this - do NOT go without hooking the cable up, as the transmission will not function properly and may explode and kill small furry animals...or something.
Re: weber carb install 88 raider automatic [Re: JohnnyBfromPeoria] #560322 01/30/05 06:06 PM
W
wyleone Offline
This is from my receipt for my Weber.
E1012 32/36 weber carb Mitsubishi
Not smog legal 83-89 2.0/2.6 $399.95
E-1009 Auto kickdown LKG E-1017/E-1012 $69.95
Montero 1999 Flyer Update Mitsubishi $0.00
This was from a:
John Baker
Hwy 35 & county Rd D
Webster, WI 54893
I did not buy this directly, It all came w/ the Raider when I bought it. I just installed it all.
So yes there is a MFG kickdown kit for the 2.6L Weber conversion.
Carbs Unlimited
or
Redline Weber
They both sell some cool accessories for the Webers too
And Redline Weber sells add on FI kits too
Re: weber carb install 88 raider automatic [Re: JohnnyBfromPeoria] #560323 01/30/05 07:44 PM
lee_raider Offline
I dunno, I heard this before too. But, like I said I used mine without the kickdown cable for several years (3 or 4) without any ill effects at all. I did "adjust" the cable for good shift points just by pulling it a bit. And I used the manual OD switch when needed.
But mine never exploded or even did anything strange in a few years......and it still works great. Although right now it is sitting on the floor of the garage, being replaced by a TH350. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: weber carb install 88 raider automatic [Re: lee_raider] #560324 01/30/05 08:11 PM
Kevin C Offline
By keeping the cable out a bit you raised the line pressure and the shift points. Having the line pressure up increases the pressure to the pistons that compress the clutches. Yours apparently was enough to prevent clutch slippage and burning out.
Its works but is not ideal, best to set it similar to the factory carb. I adapted the pulley from the carb to my throttle body. It took a little tweaking bit it does work.
Kevin
Re: weber carb install 88 raider automatic [Re: lee_raider] #560325 01/31/05 02:29 AM
W
wyleone Offline
A 350 lockup or std 350? If you ever drive on interstate. I would highly recommend a 350 lockup. You can rig it on a toggle switch or use a tp sensor. It will better your gas milage and lower your RPMs at hwy speeds.
I am wanting a 350 lockup or 700r4. I'll just upgrade the 700r4 as I see fit.
Believe it or not, when I was in the woods today, I saw a th250 under a tree. I might go get it for the parts. <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: weber carb install 88 raider automatic [Re: wyleone] #560326 01/31/05 02:41 AM
52degrees Offline
Geez, at least for the case. Parts washers are the BEST!
Clay
KG6VNX
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6302 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-05-29 22:43:06 UTC
