caliper bolt #560406 01/30/05 05:03 AM
dewmtndew Offline OP
I went wheelin today and noticed a clunk when I braked on the way home... I found out I lost the top caliper bolt(one of the two that hold the caliper on) and was wondering if anyone knows what size bolt they are.
thanks in advance
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: caliper bolt [Re: dewmtndew] #560407 01/30/05 05:54 AM
4Crawler Offline
I think mine is M12-1.25x40, might want to pull out the other one to make sure it is the same and also to see if the first holes has stripped. If so, you may either need to rethread it larger or use a helicoil or something similar.
Re: caliper bolt [Re: 4Crawler] #560408 01/30/05 06:44 AM
thanks roger. I was planning on pulling one and matching. it would be way easier if someone knew exactly though
erick
85 Pickup
Re: caliper bolt [Re: dewmtndew] #560409 01/30/05 07:18 AM
kewlynx Offline
Pick up some loctite while you're at the parts store. They're supposed to have it on there; just did the R&R on my ball joints. Little dab'll do ya.
**ubi apis- ibi salus**
Re: caliper bolt [Re: kewlynx] #560410 01/30/05 05:23 PM
OOP'S Offline
They are also supposed to be torqued to 90 ft lbs if I recall, do not have the FSM in front of me!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: caliper bolt [Re: dewmtndew] #560411 01/31/05 08:51 AM
ldivinag Offline
dont ask me why i know this, but your crossmember mounting bolts will fit just fine...
umm this is for a 90 4runner with auto and v6...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: caliper bolt [Re: ldivinag] #560412 01/31/05 09:35 AM
dont ask me why I know this but it did.
thanks alot!
erick
85 Pickup
Re: caliper bolt [Re: ldivinag] #560413 01/31/05 03:25 PM
OOP'S Offline
My question is, is it the same grade bolt? This is your brakes remember! <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
Re: caliper bolt [Re: OOP'S] #560414 01/31/05 11:58 PM
well the crossmember bolt is a little bit shorter but it held my caliper alot better than no bolt at all! It bought me enough time to drive to work school and the bolt shop. picked up 2 (im carrying a spare now) they are grade 8.8 and those are a pretty hefty bolt I think they will hold.
thanks for everyones help
erick
85 Pickup
Re: caliper bolt [Re: dewmtndew] #560415 02/01/05 04:54 AM
DerekM Offline
The thick washer is crucial on that bolt. Without it the bolt will thread into the rotor and sound like a rock is in the dust shield. Ask me how I know <img src="/forums/images/graemlins/drunk.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6314 MB (Peak: 0.7385 MB) Data Comp: Off Server Time: 2026-11-03 13:14:53 UTC
