EGR Thread Size #560959 01/31/05 05:02 PM
mph9111 Offline OP
Installing a newer version of the 2.3 4ZD1 engine into my '92 pickup. The newer style head has not been drilled and tapped for the earlier EGR manifold that screws into the head at the exhaust ports. We've drilled it out and are now ready to tap the threads. A 1/2 inch tap is too small. Does anyone know the proper size? Appears to be 20 threads per inch and is tapered (ie, pipe threads)
Re: EGR Thread Size [Re: mph9111] #560960 01/31/05 10:05 PM
mph9111 Offline OP
Appears to be a 14mm X 1.25 thread pitch. Think that is the same as the spark plugs. Oh yeah, it's not a tapered thread.
Re: EGR Thread Size [Re: mph9111] #560961 02/01/05 07:40 PM
mlclark Offline
Isuzu Moderator
Just for future reference, that is actually called the AIR rail. And yes, you are correct, the thread x pitch is the same as the spark plugs.
Michael
Re: EGR Thread Size [Re: mlclark] #560962 02/01/05 08:28 PM
N
Nazrat Offline
That got me thinking... what is the thread size of the EGR tube where it connects to the EGR valve? Looks like somewhere around 19mm.
-Tad
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs
2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.planetisuzoo.com
Re: EGR Thread Size [Re: Nazrat] #560963 02/02/05 12:40 AM
mlclark Offline
Isuzu Moderator
Tad, I think it is in the 22mm range.
Michael
Re: EGR Thread Size [Re: mlclark] #560964 02/02/05 06:31 AM
randii Offline
I'm recalling that it was a 22m socket, with smaller threads.
Hazy recollection at best, tho.
Randii
Re: EGR Thread Size [Re: randii] #560965 02/02/05 01:42 PM
Madcat Offline
Just got done fighting mine <img src="/forums/images/graemlins/shiner.gif" alt="" /> and it took a 22mm wrench to get it off.
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6164 MB (Peak: 0.6899 MB) Data Comp: Off Server Time: 2026-05-30 01:07:09 UTC
