Re: Isuzu Wizard - Starting Issues (4JX1 Engine) #561964 12/06/06 12:02 PM
Howard Neil Offline
There is another area that may be worth investigating. The throttle control. If yours is the same as my Trooper (4JX1 engine), it is "fly by wire" and not a physical connection.
I had a similar sounding problem last year. The problem, in my case, was the throttle body. The main agent did the work so I cannot help with any of the technicalities.
Re: Isuzu Wizard - Starting Issues (4JX1 Engine) #561965 12/07/06 07:58 PM
Please advise how you managed to over come this fault on your Isuzu.
Thanks and regards,
Roy Sinclair.
Re: Isuzu Wizard - Starting Issues (4JX1 Engine) #561966 12/07/06 08:37 PM
Howard Neil Offline
Roy,
I'm sorry but I cannot be a lot of help as I just let the main agent do the job. If I remember correctly, they changed the throttle body (or whatever the engine end of the throttle wire is called).
Re: Isuzu Wizard - Starting Issues (4JX1 Engine) #561967 03/08/07 11:26 PM
L
lj10 Offline
I am just experiancing the same problem,in a yr 2000 3.0Diesel wizard.. although mine flutuates (idles high and low)and if i rev and take my foot off the truck stops.. once warm its all fine, just a ***** to get going from cold...
Re: Isuzu Wizard - Starting Issues (4JX1 Engine) [Re: lj10] #561968 04/16/07 09:32 PM
bmj Offline
Me too! Has anyone managed to fix this problem??
Re: Isuzu Wizard - Starting Issues (4JX1 Engine) [Re: lj10] #561969 06/04/07 12:19 AM
MB4x4 Offline
The throttle body proved to my problem - the butterfly valve position is detected by a small carbon potentiometer which failed. This thing would cost less than $3 to buy but you have to get the entire unit, which is factory calibrated, at a cost of about $800! Don't be tempted to fit a secondhand hand part!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6125 MB (Peak: 0.6963 MB) Data Comp: Off Server Time: 2026-06-10 06:13:36 UTC
