Re: Isuzu Wizard - Starting Issues (4JX1 Engine)
#561964
12/06/06 12:02 PM
There is another area that may be worth investigating. The throttle control. If yours is the same as my Trooper (4JX1 engine), it is "fly by wire" and not a physical connection.
I had a similar sounding problem last year. The problem, in my case, was the throttle body. The main agent did the work so I cannot help with any of the technicalities.
#561965
12/07/06 07:58 PM
Please advise how you managed to over come this fault on your Isuzu. Thanks and regards, Roy Sinclair.
#561966
12/07/06 08:37 PM
Roy,
I'm sorry but I cannot be a lot of help as I just let the main agent do the job. If I remember correctly, they changed the throttle body (or whatever the engine end of the throttle wire is called).
#561967
03/08/07 11:26 PM
I am just experiancing the same problem,in a yr 2000 3.0Diesel wizard.. although mine flutuates (idles high and low)and if i rev and take my foot off the truck stops.. once warm its all fine, just a ***** to get going from cold...
[Re: lj10]
#561968
04/16/07 09:32 PM
Me too! Has anyone managed to fix this problem??
[Re: lj10]
#561969
06/04/07 12:19 AM
The throttle body proved to my problem - the butterfly valve position is detected by a small carbon potentiometer which failed. This thing would cost less than $3 to buy but you have to get the entire unit, which is factory calibrated, at a cost of about $800! Don't be tempted to fit a secondhand hand part!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6132 MB (Peak: 0.6970 MB) Data Comp: Off Server Time: 2026-06-20 18:00:47 UTCValid HTML 5 and Valid CSS
