Charge light and Brake lights are on #562565 02/03/05 10:11 PM
markshoreline Offline OP
Sorry for the rookie question, but do these lights mean the alternator is out? Does it need replacement or parts, anything else I need to check or swap out? I need to get back on the road quickly.
Thanks for your advice.
Mark
87 4runner 2.4l 5 spd
'87 4Runner with factory alloy wheels, 225X15 tires, 4banger and 5spd, 26 mpg @60-62 mph, 225k
Re: Charge light and Brake lights are on [Re: markshoreline] #562566 02/03/05 10:18 PM
4Crawler Offline
Re: Charge light and Brake lights are on [Re: markshoreline] #562567 02/04/05 02:48 AM
kewlynx Offline
To add, also check your brake and clutch fluid levels; lights are triggered when they're low/depleted.
**ubi apis- ibi salus**
Re: Charge light and Brake lights are on [Re: kewlynx] #562568 02/04/05 03:07 AM
CJM Offline
I concure with the above ... <img src="/forums/images/graemlins/cheers.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: Charge light and Brake lights are on [Re: CJM] #562569 02/04/05 03:26 AM
willzrunna96 Offline
sounds like your alternator took a crap. If theres an autozone around there will be able to test it under a load while its still in the truck.
Re: Charge light and Brake lights are on [Re: willzrunna96] #562570 02/04/05 03:28 AM
9
92daily Offline
not to highjack post but does autozone and/or advance also have a diagnostic tool to hook up and tell exactly why engine light is on??.. the paper clip is good but gives like 5 possible problems.
I'm between toyotas right now... 3rd Gen 4-runner soon.
Re: Charge light and Brake lights are on [Re: 92daily] #562571 02/04/05 03:34 AM
kewlynx Offline
If you're throwing multiple codes, then you need to figure out how one thing affects another.
FSM TIME <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />, also, check the tech articles HERE TPS and 02 sensors can toss a lot of stuff off kilter.
Re: Charge light and Brake lights are on [Re: kewlynx] #562572 02/04/05 03:39 AM
Ok, I went to the dealer and got the part for $18.36, printed off the instructions, and, "I'M GOING IN!".
Thanks for the help, I'll let you know how it goes.
Mark
Re: Charge light and Brake lights are on [Re: markshoreline] #562573 02/04/05 03:41 AM
kewlynx Offline
May as well replace your belts while you're in there.
Have fun!
Re: Charge light and Brake lights are on [Re: kewlynx] #562574 02/04/05 06:38 AM
Did the deed with the instructions and parts on this site. The model of truck in the instructions must be a different year, since my 87 only had the one bolt on wire and then the clip on connection, whereas the other one had three hookups.
Thanks, guys. This site is the only way I can keep this truck!
Mark
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6385 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-11-18 03:43:43 UTC
