Turbo Redux #562714 02/04/05 12:56 AM
fasteddy Offline OP
Bought the first round of stuff today (well, I paid some money down on it to get Phil moving).
all 89:
Starion ecu and harness and all sensors and other 1/2 B38
TB with good TPS and all of vac line sys. with all devices
Air can lid with MAS, IAT, ?MAP?, and waste gate sol. valve
Knock box, dizzy
Intercooler and hoses and hard lines
Cruise system with aux. vac system complete
a/c compressor w/ bracket and condenser and all lines/idler
Stuff to get:
SDS extra injectors controller
New primary/secondary injectors/clips
Pistons - buy/coat
Clevite77's
Hastings? any ideas?
roller hyd cam/roller lifters
new TD05-14G turbo
90.5+ a/t forlockup tc
25-2600 stall torque converter with STOUT lockup clutch
Steel tube for hard intake to turbo
ABS tube for redneck snorkel
V6 front stuff for big lsd/v6 brakes
Starion seats
2.5 tube/cat/muffler for new exhaust
new water/oil pumps
Stuff to get done
Pull/rebuild long block - maybe new head - install balance shafts/balance motor - mild intake port (flash and blend) - port exhaust mani and turbo outlet - cut/fit/weld up exhaust - rebuild front suspension - new rear axle seals/bearings
Dream stuff:
Puerto Rican/German/??? Gen1 Cabrio body - firewall back (Nitteberg, you out there?)
Re: Turbo Redux [Re: fasteddy] #562715 02/04/05 01:15 AM
FrankR Offline
inspire me
Sounds like someone did! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: Turbo Redux [Re: fasteddy] #562716 02/04/05 01:56 AM
Where to start...???
- BFT! <img src="/forums/images/graemlins/zombie.gif" alt="" />
- Are you saying that PR got Gen I J-tops?
- On the snorkel, did you see my post in the Talk thread? I have the template coming from ARB US. I am planning the same and am thinking about mounting it to that a Safari will be plug and play down the road. A copy if yours for the asking.
- Bag the Quest seats. I like my Gen IIs much more.
- If you need any help, you know where to call. You see, there's this guy down south that I learned me so much I was able to do the swap myself. <img src="/forums/images/graemlins/lol.gif" alt="" /> (And a couple more scattered across the map. <img src="/forums/images/graemlins/cheers.gif" alt="" />)
Re: Turbo Redux [Re: MontyMcV] #562717 02/04/05 04:20 AM
fasteddy Offline OP
Frank, my checking account inspired me.
Javypro says they got them, and claims it as home. I figure if US Territory, may be easier to import, and closer shipping. Hoping with a part # I can order new canvas/"windows"/seals.
I like the Starion seats for the adjustable side bolsters and thigh support. Guess I never looked close at Gen2 seats. Wish I had the bucks for Recaro's.
Re: Turbo Redux [Re: fasteddy] #562718 02/04/05 05:45 AM
Another brother-in-law of mine (not the wrench) is tight with a guy that I'm pretty sure is from PR. They guy used to work with the B-I-L when he ran his old company, and they still do work together now with is new venture. The guy still has family there. I think the B-I-L has even been there for a visit. I'm going to have to look into this. See if he can find any, etc. That would definitely be "too cool for school."
Re: Turbo Redux [Re: MontyMcV] #562719 02/04/05 06:40 PM
cragdweller Offline
Eddy, you mentioned some rebuild stuff for your rear axle? Don't know if you've thought of this, but the V6 9" pickup rear axle will bolt right in to your four cylinder SWB. A rear drive shaft from a coil sprung SWB might be a direct fit as well. If not, then your original four cylinder rear driveshaft could be shortened.
I know you turbo guys are pretty happy with the 8" rear end, but if you need to freshen it up, why not go with the extra strength of the 9"?
Sounds like a great project, regardless! <img src="/forums/images/graemlins/cheers.gif" alt="" />
1994 3.0L 4x4 pickup.
4.62 gears (4.22 stock), 33x10.5 BFG MTs. LSD rear. Five speed trans. 172K
Previously owned Mitsubishis:
1986 2.6L 4x4 Mighty Max, 1985 2.6L 4x4 D50
1987 2.6L Raider, 1989 3.0L Raider
1995 Montero SR
Re: Turbo Redux [Re: cragdweller] #562720 03/09/05 02:53 AM
fasteddy Offline OP
Interesting. I want to do a disc brake rear axle, and have some interest in 4.222 rear gears. Can you get an lsd to fit that? Maybe a rear locker for that axle? No lincoln.
I've also got to figure out a way to stop axle wrap if I get too much torque, based on what Kary and Curtis say. I'm tending toward drag bars top mounted, with a length equal to the axle-front spring eye length. Makes a poor man's trailing 4 link rear end with no panhard rod needed. I also want a rear sway bar and a beefier front bar, both with a disconnect for off road. I've also wondered if I could use the sway bar trailing arm as the drag bar. I also want to put on a Fiat Spyder or similar rear brake proportioning valve, indexed off nose dive on braking, to adjust the rears for laden/unladen stops.
Went and paid some more $ and picked up the following from my list:
intercooler and all hoses and tubes (half bottom row of fins needs straightening up - can a radiator or ac shop do this?)
throttle cable
ecu and harness and control relay with B38 and fuel pump pigtails
air can (no lid/MAP/IAT/MAF w/waste gate solenoid yet)
spark box and dizzy and coil with radio thingy
O2 sensor
cruise control computer, column lever, vac pump, vac reservoir, actuator, cable, accel pedal assy., vac switch, check valves and hoses
ac compressor, comp. bracket, 2 piece condensor, all hoses to firewall
Used stuff still to get (it started pouring rain at Phil's):
air can lid with all that stuff above
complete intake with TB and injectors and all sensors (so I get a my old intake to fool with for MPI)
cruise harness (all the cruise stuff is off an old flat side analog dash Starion)
alternator
New stuff to get for the first phase setup:
injectors (unless mine test out ok) - found some interesting aftermarket injectors on ebay too for about $350
late model starion water pump
timing set and new truck oil pump
91 V6 tranny
V6 front axle and brakes and master cylinder
I'm selling my working 85 Starion stuff as soon as I have it off the truck. You'd need to add intake (you can have my TB and injectors), exhaust and turbo and downpipe, and fuel pump and filter and fuel lines. Phil has all of that for sale.
Re: Turbo Redux [Re: fasteddy] #562721 03/11/05 02:18 PM
JAVYPRO Offline
Oh yes, I just happen to be back from my little island and happened to come across the gentleman that has the jtop it is BEAUTIFUL!!! Sorry no pics, they were not planed vacations but a family emergency. Anyway, it is that gold color with tan interiors, American racing rims with 31" BFG's you got to see it to believe it <img src="/forums/images/graemlins/drunk.gif" alt="" /> it looked great hauling a pair of SeaDoos. He promised to send me a picture so I will post it a soon as I get it. Couldn't talk for too long on the mods he had because my wife and my kids were not in the mood as their stomach were grauling.
But PR is not recommended for those with a faint heart, there are so many Monteros per square mile that you will go crazy, all colors, mods and and ... <img src="/forums/images/graemlins/scared.gif" alt="" /> I couldn't, I had to come back.
Ohhh before I forget, one cool mod that this guy had in his jtop was that he fitted a GEN II brush guard to his GEN I, very little mod and very, very sturdy so strong that it survived with no damage whatsoever a free push he gave to a Chevy Cavalier that cut in from of him, NASCAR is just childÆs play compared to the traffic jams in Puerto Rico!!!
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Turbo Redux [Re: JAVYPRO] #562722 03/11/05 02:44 PM
We need sourcing for bodies...!!! Another thought I had was how much would it cost to get the critical body parts cut off and sent here. That would get around the more complicated shipping logistics, as well as maybe the whole import-a-car issues. That and a source for the top and we are on our way.
Maybe those who are interested might get a kitty together to make it worth someone's while down there to do a little leg work for us?
Re: Turbo Redux [Re: fasteddy] #562723 05/22/05 08:58 PM
Nitteberg Offline
http://nitteberg.com
-83 Pajero SWB Soft Top 2,3TD
35x14,5x15 PitBull Rocker
Bodylift, LSD, PTO-winch, Intercooler, 2.85 gear's
Gen2 upper a-arms, flipped and raised ball
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6474 MB (Peak: 0.7773 MB) Data Comp: Off Server Time: 2026-07-17 01:10:29 UTC
