the tranny/ 4wd problem #566545 02/10/05 06:22 PM
mainer Offline OP
went and talked to the shop that did the work on it today
they couldnt figure it out...
the problem is... it wont engage/ disengage while moving.. you have to stop
and to disengage you have to be going less than like 3mph
what does this sound like?
00 tacoma 4x4 ex-cab stock 193,000 and counting
85 long bed pickup 4x4 frame off restoration. rear lock rite 31's 268,000 miles
51 cj3a stock everything orginal 2500 original miles
Re: the tranny/ 4wd problem [Re: mainer] #566546 02/10/05 10:15 PM
That is the way my 2000 4runner works. Must stop to engage and go slow to disengage. The book says you should be at full stop to do both. I don't think you have a problem.
Re: the tranny/ 4wd problem #566547 02/10/05 11:18 PM
mainer Offline OP
in the book it says on the fly engage up to 25mph....
and the shop specifically said they couldnt figure out why it was hard to engage/ disengage
like sometimes its really hard to get it out of 4wd
Re: the tranny/ 4wd problem [Re: mainer] #566548 02/10/05 11:32 PM
I have a 5spd and it doesn't like to go into 4wd unless I let off on the gas. As in no shifting into 4wd under load...which makes sense anyway. I changed the transfer case to Redline synth and it shifts much better now.
Re: the tranny/ 4wd problem #566549 02/11/05 04:38 PM
JohnJerk Offline
I forget what year truck you are tallking about now, but the older systems will be hard to get in and out of 4wd if:
1. the tires are not all the same size, or
2. you are driving on pavement
One of your other posts indicated you drove a mile back to the guys house - made me wonder if you aren't on dry pavement. The newer systems would seem not to care about these issues, however. Good luck.
Edit - I just looked at your other two posts on this same topic. You should only have one post as people, like me, are now telling are telling you info someone else already did...and we don't know the year, miles, etc in this string.
2006 Tacoma Crew Cab 4x4 Auto TRD Off Road
2002 4runner SR5 4x4 79K miles (Sold)
1993 Pickup Ext. Cab 22RE 4x4 82K miles (Sold)
Park City, Utah
Re: the tranny/ 4wd problem [Re: mainer] #566550 02/12/05 02:10 PM
mainer Offline OP
guy called last night and aknowledged there is a problem with the tranny/ 4wd and said he'll take $3500.... and show me the slip that he paid $4000....
Re: the tranny/ 4wd problem [Re: mainer] #566551 02/12/05 02:58 PM
min eis hard to shift as well. i think its a combo of getting used to it and changing the TC oil.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6136 MB (Peak: 0.6903 MB) Data Comp: Off Server Time: 2026-07-16 08:50:44 UTC
