Another driveshaft question.... #567723 02/13/05 04:26 PM
gcinque Offline OP
How can I tell if my rear driveshaft needs to be replaced?? The mechanic told me it needed to be replaced because something inside was broke, he took a screwdriver and tapped the it and it sounded hollow inside <img src="/forums/images/graemlins/confused.gif" alt="" />. I'm thinking this is a load of bull*****! Am I wrong?
Thanks for any input you guys might have.
gcinque
03 Tacoma Xtra cab 4cyl 5spd
89 4Runner/Jasper reman 22RE/Auto SOLD
98 Tacoma Xtra cab 4cyl Auto SOLD
Re: Another driveshaft question.... [Re: gcinque] #567724 02/13/05 05:32 PM
4Crawler Offline
Well, the driveshaft *is* mostly hollow. Unless the tubing is damaged, no need to replace it. U-joints can be replaced if they are worn or loose. The slip yoke can also be replaced if it is worn out.
Re: Another driveshaft question.... [Re: gcinque] #567725 02/13/05 05:41 PM
BrokeAsAJoke Offline
My "new" 84 ext cab has a bad vibration around 45mph. When I inspected the driveshaft, It looked like the U - joints had been replaced recently and someone had smothered the center bearing housing with silicone (the type you use on bathtubs). Any ideas on what they were trying to accomplish? What steps can I take in troubleshooting the vibration myself?
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
Re: Another driveshaft question.... [Re: BrokeAsAJoke] #567726 02/13/05 06:27 PM
4Crawler Offline
I have some tips on my web page for troublshooting driveline problems. Sounds like perhaps the center bearing is worn out, maybe it was loose and the PO was trying to keep it from moving around too much. They can be replaced or see the Tech section for how to eliminate it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6056 MB (Peak: 0.6614 MB) Data Comp: Off Server Time: 2026-06-17 06:43:41 UTC
