Sluggish Acceleration?? #568156 02/14/05 02:38 PM
rmg Offline OP
1995 2WD T100 with 200K. I have been experiencing sluggish acceleration when the engine is cold for about 6 to 9 months now. I press the accelerator and the engine just bogs down. I haven't done much to figure it out, but this weekend I pulled the MAF to check it out. According to the FSM, I should be getting a resistence reading. Guess what, nothing. Doesn't even register. But, if I start the engine with it disconnected, it dies. Is the MAF bad and need replacing?
Also, I found my battery ground wire was not attached. Don't think this could be the problem, but thought I would ask.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Sluggish Acceleration?? [Re: rmg] #568157 02/14/05 03:31 PM
mikem Offline
I don't know about the MAF and all, but you should try to clean up the intake path antway.
Also, my '95 was doggy, and would produce a check light if I accelerated hard. So, I tried some fuel injector cleaner and top-end cleaner (sucked in through a vacuum port in the intake manifold). It helped, but didn't totally remedty the sicuation.
Then I just tried running several tanks of premium (Chevron and Shell) and I swear it runs better now. No check engine light since. So now I run premium every other tank or so.
Your results may vary.
1995 T100 SR5 XCab 2WD Auto
Re: Sluggish Acceleration?? [Re: mikem] #568158 02/14/05 04:42 PM
rmg Offline OP
Now that you mention it. I did a SeaFoam treatment a few months back and it didn't seem to help. I also changed the fuel filter and did a test with premium gas for about 3 months without any improvement. The spark plugs have been changed regularly along with the air filter, oil, and minor stuff.
Any other suggestions. After it is warmed up, it doesn't feel sluggish.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Sluggish Acceleration?? [Re: rmg] #568159 02/14/05 08:56 PM
4
4xGeek Offline
Checked your PCV? Just a thought... <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Sluggish Acceleration?? [Re: 4xGeek] #568160 02/14/05 09:08 PM
rmg Offline OP
Yep. Checked that a while back. It has to be something to do with the engine temp. When cold it is sluggish, when warm it is normal. Almost like the ECU is getting bad information from somewhere on how to mix the fuel and air. I read somewhere that someone thought it could be a vacuum leak. When the engine is warm that it might not be as apparent. I don't know.
I will monitor a little closer the next few days and see what I can come up with.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Sluggish Acceleration?? [Re: rmg] #568161 02/14/05 10:29 PM
4
4xGeek Offline
Could be something as simple as your thermostat... Probably make you run like crap if that's stuck wide open while your engine is still cool. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
Re: Sluggish Acceleration?? [Re: 4xGeek] #568162 02/15/05 12:07 AM
rmg Offline OP
Thanks 4xGeek. I knew someone would throw out a DOH!! comment that I hadn't thought of yet. I bet you hit the nail on the head. I have to do the timing belt soon, so I will check the thermostat then.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Sluggish Acceleration?? [Re: rmg] #568163 02/15/05 12:15 AM
4
4xGeek Offline
Gotta love those... <img src="/forums/images/graemlins/lol.gif" alt="" /> Let us know how it works out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
Re: Sluggish Acceleration?? [Re: 4xGeek] #568164 02/16/05 05:11 AM
thecat Offline
Whats the deal mine has a slight hesatation when you slightley hit the gas not flooring it. Driving me nuts.
Toyota master
Re: Sluggish Acceleration?? [Re: thecat] #568165 02/16/05 09:41 AM
4
4xGeek Offline
Fwiw, opening up my intake tract helped my throttle response... <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6374 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-06-09 23:19:21 UTC
