adj. valves at .007 & .011 cold now its loud as hell hmmmph! #568488 02/15/05 12:12 AM
MattR Offline OP
Today it was time to adjust the valves again, so I figured I'd do the cold method this time around (I used to always do it hot) adjusted the intake at .007 and exhaust at .011 as per the FSM instructions, and like magic the valvetrain now drowns out my stereo...what gives??? Am I missing something on this? never had any problems before. Thanks
Matt
04' Ford Ranger XLT 4.0l (Mr. sensible)
There are 10 kinds of people in this world that understand binary, ones that do, and ones that don't.
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: MattR] #568489 02/15/05 12:29 AM
ArbitraryNotion Offline
How old are the adjuster screws? Did you check their condition?
If they are worn badly, turning them won't really adjust them correctly, just make it slip/click around.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: ArbitraryNotion] #568490 02/15/05 02:18 AM
You didn't overtighten the valve cover, did you? Sometimes that gets tightened down too much and the rockers can make contact and a lot of noise. Try loosening them up a little first. I remember having to adjust the valves several times to get it running right and keeping it quiet.
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! #568491 02/15/05 03:03 AM
MattR Offline OP
Good point Jeff, Dont think that would be it though I'll have to check it tomorrow, I left the garage frustrated and gave up for today so I'll have to come back with a cool head tomorrow and see what gives. I know I only snugged up the valve cover like usual this isnt the first time I've done this, hmm I dunno. The adjusters only have 30,000 miles on them so that couldnt be it. I just dont get it this time. My neighbor came home later and he has a 94 pickup with the 4 cylinder and his is whisper quiet, all you here is a slight tick from the injectors, to hear that... that was very frustrating. Oh well try again I guess.
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: MattR] #568492 02/15/05 03:57 AM
Did you check the rocker arm spacers? How bout exhaust leaks?
Josh
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: ArbitraryNotion] #568493 02/15/05 05:19 AM
J94_4runner Offline
is this on a 3.0 or 4cyl?
www.celicasupra.com
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: J94_4runner] #568494 02/15/05 05:24 AM
MattR Offline OP
4 cylinder, everything else passed my visual inspection though I'm no professional. I must have just forgotten something really simple. <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: adj. valves at .007 & .011 cold now its loud as hell hmmmph! [Re: MattR] #568495 02/17/05 04:02 PM
missouriman Offline
like said above if the adjustment screws are old they will be worn in one spot. Kind of like a step on the surface and when you adjust them if you are just on the corner of said step it will beat it down pretty fast. the step I am talking about would look something like a quarter moon stamped/worn into the face of the screw.
hope that made some sort of sence.
I just used a sharpening stone to round mine back down.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6234 MB (Peak: 0.7170 MB) Data Comp: Off Server Time: 2026-11-17 11:25:37 UTC
