Taillight malfunction #568559 02/15/05 01:47 AM
marcre Offline OP
About a week ago my left blinker arrow on the instament cluster began to illuminate when I hit the brakes. I assumed it was a bad bulb, but that is not the case. I went to replace the bulb today, I noticed the old bulb still looked good. I replaced it anyway and still the same problem.
I then placed a 2x4 on the brake and went to have a look and to my surprise when the brake is pushed in the driverside front and rear turn signals come on as well. They do not blink they come on solid.
Am I correct to think there is a short somewhere? I know nobody can tell me where the short is, but where do I look. I assume I start at the tail lights and work my way to the front. What I am wondering, is there a trouble spot where I should look first. Also, does the wiring run up the side of the car and under the carpet by the doors. Where does the wiring go once it gets to the front of the vehicle? I noticed that when I had the assembly for the taillights appart there was a ground wire attached to the body, I will first tighten and clean that, but it looked good, so I doubt that is the problem.
There are a lot of wires to look at in this area, so it looks like it may take awhile.
I guess what I need to know is if there is a trouble spot to look at. Hopefully this is not to hard to fix, because I do not want to take it in to a mechanic.
Thanks,
Marc
I did a search and did not see anything.
99 rodeo 4x4 v6 80,000 miles
My Rodeo
Re: Taillight malfunction [Re: marcre] #568560 02/15/05 02:07 AM
Jim_Paget Offline
One typical place for this type of short is in a trailer wiring harness, if you have one.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Taillight malfunction [Re: Jim_Paget] #568561 02/15/05 02:10 AM
marcre Offline OP
Yes, I have one. I have never used it though. What would I be looking for on that, just some bare/frayed wire. I know the wiring harness was put on when the original owner bought the truck. That was in '99.
Should I remove the harness?
Thanks,
Marc
My Rodeo
Re: Taillight malfunction [Re: marcre] #568562 02/15/05 02:13 AM
Jim_Paget Offline
I don't drive a 2nd Gen, but from other posts, I believe that most of the harnesses on your vintage rigs are a plug in harness, so it should be easy to disconnect it without a lot of hassle. Try seeing where it enters the body and you should find the connector.
Good luck!!
Jim Paget
www.rrr4x4.com
Re: Taillight malfunction [Re: Jim_Paget] #568563 02/15/05 02:17 AM
marcre Offline OP
Thanks for the help Jim, I'll try that.
Marc
My Rodeo
Re: Taillight malfunction [Re: marcre] #568564 02/15/05 04:00 PM
BigSwede Offline
Yeah, I would do unplug the trailer wiring first 'cause it's easy...if that is no fix, then get a schematic and look for a bad ground "somewhere" in the lighting system...when the ground is bad the juice will go all over the place looking for a way out, including through other fixtures. Kindofa PITA I'm afraid...
Serenity now!
Re: Taillight malfunction [Re: BigSwede] #568565 02/15/05 08:49 PM
marcre Offline OP
What is the best way to clean a ground? Should I clean it up and sand it down?
Thanks,
Marc
My Rodeo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6160 MB (Peak: 0.6950 MB) Data Comp: Off Server Time: 2026-06-07 06:51:51 UTC
