Page 3 of 3 1 2 3
Re: Lift/Tire question #568586 02/15/05 08:10 PM
Staceman Offline
I had 33" tires with stock 4.10s in my 85 4Runner for a while. Sure, the odometer said I was going 60MPH, but my GPS said I was doing 76! Sure, my trip meter said I got 200 miles per tank, when actually it was more like 285. You really don't lose gas mileage like the newer taller tires are telling you. Still, switching to 4.88 can't be beat. Holding a true 75mph up and over freeway overpasses and what not is a nice thing.
Re: Lift/Tire question [Re: trcdrunner] #568587 02/15/05 08:21 PM
Hey trcdrunner!
Thanks a lot man those pages helped a lot I found that I have a 4.30 gears... I had the code G282, which was the same code as he had... thanks a lot ian
For example, my Japanese truck's code is G282. This means I have an 8-inch (rear) axle, 4.30 gears (which is common with automatic transmissions), and a 2-pinion design (common in 4 cylinders).
Ian
Re: Lift/Tire question #568588 02/15/05 11:10 PM
jcssurf Offline
4.30s in an auto give no advantage over 4.10s in a 5 speed. The autos have a taller 4th (and final) gear than the 5 speed which is why they were geared lower (and maybe to help acceleration?). Toyota eventually went to 4.56s with the auto 4cyls with the 28" tires to make up for the gap.
But, with that said I think it wouldn't be that bad. I would say leave it in 3rd unless you are going downhill, and leave the ECT power-mode on. The torque converter will make it better off the line than the 5speed. But don't expect phenomenal gas milage.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: Lift/Tire question [Re: jcssurf] #568589 02/16/05 02:32 AM
Ya I think I am going to try some bigger tires.. when I first bought my 30's I posted a picture on here and someone said.. nice tires but your gonna want bigger real soon haha...
but my wheels are 15x7.5... with the BFGoodrich AT's whats the widest tire that I could get to fit on these if I want 33's?
Thanks Ian
Re: Lift/Tire question #568590 02/16/05 02:54 AM
jcssurf Offline
Are you sure they are 15x7.5 and not 15x8?
Either way, you could do 12.50s, you just may need to run a lower pressure (like 25-30) around town to get them to wear evenly.
-Driver
Re: Lift/Tire question [Re: jcssurf] #568591 02/16/05 03:04 AM
Ya I thought the 15x7.5 was kind of weird to but I forgot what they were and just went and looked at them and thats what they said... damn they could fit 12.5? or would just 10.5 be the best?
Ian
Re: Lift/Tire question #568592 02/16/05 04:09 AM
I'm running 32x11.50 on the stock Toyota wheels which are 15x7. 33x12.50 can be put on the 15x7 rims, but I wouldn't recommend it. The tires bulge out a lot.
Re: Lift/Tire question #568593 02/16/05 08:39 AM
trcdrunner Offline
Hey trcdrunner!
Ian
No prob - glad it helped!!!
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: Lift/Tire question #568594 02/16/05 01:29 PM
TexJeff87 Offline
I'm running 35-12.50's on my stock wheels. They bulge some, but here's why I did it. One, I figure that much sidewall will make up for the skinny wheel. Two, I'll never pop a bead. Three, I was out of $$. Four, gotta tell you it looks good.
If Mad Max had a 4runner...
Re: Lift/Tire question #568595 02/18/05 09:05 AM
jvmin Offline
here's what I know from experience
I've had my 84 std cab truck with a 5 speed since jan 85
it has been through the different mods up to what it is now.
I ran 33x12.5x15 with the stock 4:10 gears and a body lift and it was a real dog on the milage and power.
but I drove it that way for several years and just learned to live with it. top speed was around 74 mph
then I got 4:88's and hated them since they were more than I needed for 33's but keep in mind that I had gotten used to driving with the 4:10's
it would go about 92 mph top speed with the new gears and 200k miles on it down hill with a tailwind.
then I got a 3" suspension lift which raised it higher increasing the under body air flow even more and it slowed it down about 4mph
that and the fact that it at that point had 220k on it
I then swapped in a buick v6 and went to 35" tires and the 4:88's were too much gear for the v6 so I dropped back to 4:56's and the top speed now is up around 120 if you'd ever want to drive that fast.
the 33's and stock gears and mud did ok
in the sand they did fine
on the hills they did ok
I did notice that my brakes were wearing out twice as fast
my clutch was replaced more often than it should have been
and I actually smoked it twice
once while wheeling with the 33's and stock gears trying to climb a really steep hill.
and once in the mud trying to use third gear speed shifting to get more tire speed.
since I swapped in the right gears and the bigger engine
it is so much more hyway friendly and with the crawlbox I don't have any problems on the trail.
I will make a suggestion
if you do regear it later go ahead and get a locker at the same time.
you'll really love it with a locker
if I had known what a difference a locker made I would have gotten that over bigger tires and a lift
for about 200 bucks you can get a locker for the rear and it will be a whole new experience to drive
bigger tires help but a locker makes so much more of a difference it isn't even funny. and when you get in those crossed up situations where one front tire and one rear tire is spinning the locker takes over and in most cases you could drive right on through or at least back out.
don't get me wrong the bigger tires made a huge difference
33's compared to stock was like night and day but soon I was getting stuck with the 33's every time I went wheeling
so i bought a winch. then I bought a locker and there have been only a few times where I neeeded the winch for my truck. it has gotten most of it's use from pulling others through stuff I just drove through.
good luck with it
you can get by with 33's and stock gearing
and just remember that it won't be a power house by any means
the new gears later will make it a whole new vehicle when you finally do it.
and be real mindful about the brakes the bigger tires do where them out faster.
if you go mudding take the time when your done to wash it underneath around the rear brake drums
I usually take the little plugs out and stick the pressure washer in there and let it flush it out. or drive it through a creek at least as deep as the drums.
get around the pinion too
pinion seals aren't fun to replace.
and wash out around the cvs and stuff as well as the transfercase outputs.basically any moving parts where seals are involved.
u joints
cv's
brake drums
front brake area
pinion seals
transfer case seals
front engine cover seals
alternator
airconditioner compressor
back of your hydraulic fan clutch
air pump
power steering pump
steering box and steering components
and if you mudding with friends and have been behind them while their slinging it then wash out the radiator fins
most people forget the engine areas and then wonder why their truck leaks oil like a seive. and the third is making a noise.
mud running is fun
it's the clean up that's rough even if you don't have
the time when your done wheeling in the mud
you can put your sprinkler under it and let it wash it out for a while moving it around several times in the process.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6389 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-06-07 02:20:43 UTC
