SAS Swap in trooper #568879 02/15/05 06:21 PM
Roberts89trooper Offline OP
Hey will a toyota solid axle work for a trooper
TO wide
To narrow
heavy enough
ect...
Any info would help.
Thanks Robert <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: SAS Swap in trooper [Re: Roberts89trooper] #568880 02/15/05 08:32 PM
paulevans76 Offline
yes it will work, and it has been discussed about 5 thousand times. try the search <img src="/forums/images/graemlins/smile.gif" alt="" />
88 Troop - Posing yard art
Re: SAS Swap in trooper [Re: paulevans76] #568881 02/16/05 06:17 PM
Tried the serch did not find much on width or very good details of this procedure. I guess it will be a learning experince. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: SAS Swap in trooper [Re: Roberts89trooper] #568882 02/16/05 07:03 PM
RobG Offline
you won't find exact details, mainly because every SAS is different... the parts you choose, what you're looking for out of it, etc.
but reading all the posts out there will educate you on the general process and your options... then, come back with specific questions and everyone will be glad to help you.
there is one answer for exact SAS procedures.
-Rob
Re: SAS Swap in trooper [Re: Roberts89trooper] #568883 02/16/05 07:06 PM
Rodeo Clown Offline
Toy Axle
General SAS Info
And Another
More Toyota Stuff
SAS Archive
One More With Good Info
That should be plenty of reading, and help you come up with some more specific questions. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: SAS Swap in trooper [Re: Rodeo Clown] #568884 02/16/05 11:11 PM
paulevans76 Offline
to save you a few minutes, the width on the mini truck front (79-85) is 55.5", rear is 55", rears for 86+ are 58". most who do a yota front run 1.5" spacers each side. 84 and 85 are the best years, they have the most bracing to prevent bent tubes.
one axle I would be looking at if I didn't just get a 44 is the FJ60 front. 60", sprung under, same internals as the mini truck but the short side shaft is longer <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6135 MB (Peak: 0.6853 MB) Data Comp: Off Server Time: 2026-06-07 07:01:29 UTC
