Pinion Nut Size #569716 02/17/05 07:29 AM
My pinion seal is leaking. Does anyone know the size of the pinion nut? Im guessing this is an easy fix. Just a matter of removing the driveshaft, checking the amount of torque on the nut, swapping it. Any missing steps to get to the seal?
93 Pickup V6. I think Marlin has the seal... is it that a good place to get it? Or will NAPA suffice?
Thanks
Re: Pinion Nut Size #569717 02/17/05 09:06 AM
Lou Bell Offline
The nut is 30mm. I got a 30mm impact socket from napa. You can get the seal from napa, but Marlin carries the origonal japanese seals that toyota uses which are higher quality. Be very careful to return the pinion nut EXACTLY where it was on the pinion, as there is a crush sleve inside that holds a certain amount of bearing pre-load on the pinion bearings. Dont forget to stake the nut when you're done.
'87 4runner 37x12.50x15 MTRs
SAS, 4.88's, rear+front e-lockers
4x4Him --- Christian 'wheelin
4x4Him National Forum
Re: Pinion Nut Size [Re: Lou Bell] #569718 02/17/05 04:55 PM
PARANOID56 Offline
i thought it was a 32mm socket? its been a while since i replaced that seal, so i cant remember. everything else the above said is corect, make sure you put that nut back on the same amout of turns.
Shane
PARANOIDS PAGES Of all the things I lost, I miss my mind the most.
1984 Toyota 4x4 SR5 X-Cab
1971 Toyota FJ40
2006 Subaru WRX wagon
Re: Pinion Nut Size [Re: PARANOID56] #569719 02/17/05 04:57 PM
4Crawler Offline
30mm is the size, same for the pinion and t-case flange nuts.
Re: Pinion Nut Size [Re: 4Crawler] #569720 02/17/05 05:57 PM
J94_4runner Offline
FYI: napa will charge you like $30+ for that socket. go to Harbor Freight and you can get a whole "HUGE" socket set for that price. that's what i did.
www.celicasupra.com
Re: Pinion Nut Size [Re: J94_4runner] #569721 02/17/05 06:03 PM
4Crawler Offline
I found one at HF in the random socket bin, I think it was $2 or so. You can also get one at many auto parts stores, look for front axle nut sockets, 30mm is the same size as used on VWs. But yes, you can get a full socket set for $30-40, I picked up a massive 3/4" socket set, works great for those big nuts. Slip a length of pipe over the end of the breaker bar and it'll take off the tightest fastener. Plus the big sockets make excellent arbors for pressing in/out bearings, seals, etc.
Re: Pinion Nut Size #569722 02/17/05 07:15 PM
Adam F Offline
I bought mine from Sears. I forget how much it was though.
97 4R, stock, daily driver
Re: Pinion Nut Size [Re: Lou Bell] #569723 02/17/05 11:16 PM
Stake the nut? I am unfamilure with this term.
Thanks for the help.
Re: Pinion Nut Size #569724 02/18/05 12:58 AM
4Crawler Offline
Groove in the pinion shaft, flange on the nut, center punch to dimple the flange into groove to stop the nut from loosening, stake and groove at about 4 o'clock in this picture:
Re: Pinion Nut Size [Re: 4Crawler] #569725 02/18/05 01:04 AM
kyle-22r Offline
so far every time i've tried to stake one of these nuts after removing them, they seem to just kind of break. material must've gotten brittle over the years, toyota recommends replacing them after every time they're removed
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6318 MB (Peak: 0.7381 MB) Data Comp: Off Server Time: 2026-07-09 22:20:36 UTC
