Welding on axle housing? #570178 02/18/05 04:17 AM
I was just wondering if it's possible to warp an axle housing when welding a truss on? Has anyone done this? Is it possible if you lay a lot of short beads? Any help is greatly appreciated.
Re: Welding on axle housing? #570179 02/18/05 05:49 AM
O
oldsub86 Offline
I'd be careful. There is no reason why you can't tack and fil with short welds instead of long ones. Let it cool a bit in between and you should be fine.
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: Welding on axle housing? #570180 02/18/05 05:49 AM
kyle-22r Offline
yeah, the recommended method is to go in about 2" beads and skip around. go slow and you shouldn't have to worry smile
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Welding on axle housing? #570181 02/18/05 05:51 AM
OOP'S Offline
Very possible, I did it. <img src="/forums/images/graemlins/lol.gif" alt="" /> If I were to put another one on I would leave the housing bolted to the springs. Use short welds 1-1.5 and let cool before going to the next spot. To do it right you really need a "Jig Bar" set up.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Welding on axle housing? [Re: OOP'S] #570182 02/18/05 06:09 AM
J94_4runner Offline
how do you know if you warped it? what is the method of checking?
www.celicasupra.com
Re: Welding on axle housing? [Re: J94_4runner] #570183 02/18/05 06:10 AM
kyle-22r Offline
if you can't get the birfs in it's probably warped
'91 4x4 shortbed
22R-E, W56, the dd!
heating cast #570184 02/18/05 06:15 AM
hazman Offline
All that I know about welding on cast is that you need to heat up the area to be welded. rj
Re: Welding on axle housing? [Re: OOP'S] #570185 02/18/05 08:50 PM
Just wondering what a "jig bar" is? Also, I will be trussing the rear differential.
Re: heating cast [Re: hazman] #570186 02/18/05 08:58 PM
DirtyHarry Offline
Toyota Moderator
Toyota housings, like Ford 9"s, are stamped steel and very easy to weld on to.
Welding axle housings [Re: DirtyHarry] #570187 02/18/05 10:28 PM
Red_Chili Offline
Toyota Section Staffer
As mentioned, use short lengths of weld, tack in place, allow to cool completely, repeat until finished. Use patience. Its called stitch welding. The Toyota housings are thin (strong enough, but light enough too) and easy to warp if you don't keep your wits about you.
That said, I've welded on my housings without consequence, following the above. If you want to test your ability, try welding 18ga. together over a long seam using stitch welding. I did so making my half doors, lemme tell ya, I learned about warpage!!!
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6361 MB (Peak: 0.7569 MB) Data Comp: Off Server Time: 2026-06-17 10:31:50 UTC
