Page 1 of 3 1 2 3
YJ Gas Mileage #570708 02/19/05 04:00 PM
I am looking into buying a jeep, to drive to work, and was wondering the difference between the 4 cyl. and 6 cyl. gas mileage wise.
Re: YJ Gas Mileage #570709 02/19/05 05:15 PM
BigJim Offline
You will have to get closer than that! Give us the year of BOTH and is it a stoplight drive or a freeway drive!
The newer year model you get the better milage you will get from either. In the best of tune 18 is a good high number you could expect.
Re: YJ Gas Mileage #570710 02/19/05 05:41 PM
JeePete Offline
Much depends on how you drive of course. Here is a link to roughly compare different year models and engines. http://www.fueleconomy.gov/feg/findacar.htm
Re: YJ Gas Mileage #570711 02/19/05 10:40 PM
NCBBA2358 Offline
Experience from my friends with the 4-cyl. engines in their Jeeps is that the reduced power output winds up being compensated by lower fuel economy. They compared their fuel usage compared to that of a 6-cyl. (mine) and found that they were actually getting worse mileage than the larger engine since they were having to push harder on the narrow pedal more often to do their normal driving.
This is based on a `91 YJ comparison. Improvements/restricions over the years may very well have changed all this.
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: YJ Gas Mileage #570712 02/20/05 03:32 AM
driver777c Offline
I have a 95YJ with a 4cyl, 5speed. I get around 17 mpg with 31-10/50 tires. I drive it daily to work. 10 miles interstate, 10 miles curvy mountain blacktop, 6 miles steep,muddy,rocky,or dusty if it has not rained mountain road. The only time it feels weak is when I first hit the interstate which is about 3 miles up hill. I dont shift to overdrive until I get to the top of the mountain. My Jeep might do better with smaller tires but I'll probably keeep the ones I have till they are worn out. Hope this helps. <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
78 F-250 4x4 that I bought new, 76 CJ5 I should never have sold. 00 F-250 4x4, 95 Wrangler, Caterpillar 777C off road mining truck that I drive for a living.
Re: YJ Gas Mileage [Re: driver777c] #570713 02/20/05 06:32 AM
Reign Offline
i dont know why but my jeep seams to get most than others, even stock ones. i get 18mpg roughly, i have 94 jeep4cyl 5speed, with 35in tires and 4.88 gearing with a stock drivetrain.
94'YJ, I4, 4in sky jacker lift kit, 2in body, 35 12.50 pro comps, arb snorkle, detroit lockers
Re: YJ Gas Mileage [Re: Reign] #570714 02/20/05 06:35 AM
BigJim Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: YJ Gas Mileage [Re: BigJim] #570715 02/20/05 07:10 AM
NCBBA2358 Offline
BigJim, there is a "home" they call "the farm" just up the road on my way into town.... they have movie time in the afternoon, coffee all day long and nurses to help you remember when you have to take YOUR MEDICATIONS!
You are a nut....
As for getting better than other gas mileage....
I find that I get far better mileage when I put better gas in the tank. When I stop by the Vidette Country Store and fill up with their best stuff, I get crappy mileage and crappy performance. When I go to Amaco or BP, and put the good stuff in, I get great mileage and can do hills in 5th! Yea!!!!!!
Keep that in mind when comparing 4 cyl vs 6 cyl....
Re: YJ Gas Mileage [Re: NCBBA2358] #570716 02/20/05 06:52 PM
BigJim Offline
Vidette I can see it now. In next years Jeep manual it will say "We hear from Georga that if you put "better" gasoline in here you will get more miles per gallon! So those of you buying a Jeep and living in Georga may find this to be true."
Vidette 87 octane is just that, 87 octane. We all have Jeeps too and most of us cannot tell one tiny bit of difference in gasoline.
Re: YJ Gas Mileage [Re: BigJim] #570717 02/20/05 08:20 PM
NCBBA you keep insisting that there is more power in different gasolineÆs. Octane only helps resist predetination under pressure and temperature, that is why you can't run 87 in your 11.5:1 Camaro. Putting 92 in it doesn't raise the power; it just allows it to run without detonating. Putting 87 in an 8.8:1 motor doesn't fetch anymore power. If you have so much carbon built up that you are running too much compression, the knock sensor will detect it pinging pull the timing back, and you lose some power. Perhaps the reason yours runs so much better on higher test gas is because of carbon build up or an over active knock sensor? For all the rest of us 8.8:1 4.0Æs there is no difference in power with 87 cheapo gas, and 104 racing gas.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6361 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-10-24 23:14:47 UTC
