2" BL installed - shifter problems...
#570951
02/20/05 03:08 AM
got it installed and my truck wouldn't shift. The lever was hitting the metal bracket that goes around the rubber boot. The bracket could be modifed but I think I would have to hack out the whole center section and the rubber boot I think would still feel like it's beeing stretched - because it is, it's 2" higher and the lever throw is further than what it was. So what should I do to fix this? Any ideas?
Thanks TBob
TBob All but SAC'ed! Had God not driven man from the Garden of Eden, the Sierra Club would have. P.S. Greenies SUCK!
Re: 2" BL installed - shifter problems...
[Re: AZTBob]
#570952
02/20/05 06:30 PM
from what i have heard the shifter lever might need to be extended you know cut the lever and add a peice in
#570953
02/21/05 05:16 PM
spend 50 bucks and get a short throw shifter...
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
[Re: CraShYota]
#570954
02/21/05 08:33 PM
what X said. i had the same problem with mine. i cut out the center section of the metal bracket like you mentioned and it did allow the shifter into position but it streched the boot so much that i kept tearing them. once i extended the shifters it all went away.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!! 2005 Tundra Quadcab.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5949 MB (Peak: 0.6521 MB) Data Comp: Off Server Time: 2026-06-20 17:42:43 UTCValid HTML 5 and Valid CSS
