Test external IC voltage regulator? 84 pickup #570955 02/20/05 03:58 AM
toowacky Offline OP
84 4x4 pickup
New battery & alternator, (w/ old external regulator).
Not charging before swapping out both of those (voltage across terminals w/ engine off and on is the same, and charge light on when the engine is running), and I know it was dumb to just throw parts at it, but what's done is done... Battery was due to be changed, and I thought that it was just the alternator that died.
To add to this, one of the previous owners had a dual battery setup using an isolator (Sure Power 702). I thought this might be at issue, so I grabbed the install/troubleshooting PDF from them and it passed the engine off tests (should have battery voltage on "A" (to ground) and "Batt 1" (to ground) terminals when engine off). Battery 2 doesn't exist anymore and wire to that from isolator is cut and capped (this way since before I've owned the truck). I think that the isolator is OK based on this test, but I'm not positive. Could it pass this test and not allow charging voltage to get to battery?
Connector going to voltage regulator has 5 wires:
-large white
-green
-yellow
-red
-white w/ black stripe
Can I test the voltage regulator w/ a multimeter? I'm thinking there must be a way to check resistance and/or continuity across a couple of those...
Any help would be appreciated-- electrical work is not my strength, although I'm trying to learn... probably just missing something stupid...
Thanks!
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: Test external IC voltage regulator? 84 pickup [Re: toowacky] #570956 02/20/05 05:11 AM
kewlynx Offline
Carefully inspect your alternator harness. These ol' trucks have a wear issue; ya think? Here's also some wiring diagrams for you:
Figures 55 thru 58
I just scored an 83 FSM, but it hasn't shown up at my door yet; otherwise I could offer.
If you haven't already taken the alternator to a parts store to have them check it for you, you might do that. Also call to see if they have anything to check your regulator; wouldn't hurt.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.019s) Memory: 0.5921 MB (Peak: 0.6413 MB) Data Comp: Off Server Time: 2026-11-17 11:02:07 UTC
