symptoms..
#570994
02/20/05 06:27 AM
the symptoms are too bad yet but get more noticeable, i feel like a sort of popping from my front end not too much jumping in the jeep but it feel and sounds kinda like large clumps of mudd banging against my body. 1) only in left hand turns 2)front drive shaft feels fine and spins fine by hand 3) so far only in 2wd, have yet to test 4wd 4) friend said feels like its in the passenger wheel well and suggested bearings
any input would be appriciated thank you
~Reign
94'YJ, I4, 4in sky jacker lift kit, 2in body, 35 12.50 pro comps, arb snorkle, detroit lockers
Re: symptoms..
[Re: Reign]
#570995
02/20/05 06:31 AM
Check the front axel U joints. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: symptoms..
[Re: JeePete]
#570996
02/20/05 06:45 AM
alright i'll crawl under tomm before work, hopefully replacing axles soon
Re: symptoms..
[Re: Reign]
#570997
02/20/05 07:06 AM
could be the U-Joints on the axle. When you are going in a straight line, nothing? when turning, does it do it more or less at higher speeds, creeping into a parking space, what?
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: symptoms..
[Re: NCBBA2358]
#570998
02/20/05 07:24 AM
a right into my drive way and nothing, but a left into a parking space and i feel it, and i can only think of one time after a turn still getting straight it did it
Re: symptoms..
[Re: Reign]
#570999
02/20/05 08:37 AM
Just a thought, if it doesn't make it handle differently it could be a loose shock, or a worn spring bushing.
Re: symptoms..
[Re: Reign]
#571000
02/20/05 02:33 PM
I've heard of the loose shock thing.... I actually saw a Jeep rolling down the road that had lost a shock and it's tire was bouncing up and down madly! Thought it was really strange.... When you had all those toys installed for your SkyJacker and the body lift, how much of the suspension on the front, as well as steering components were replaced or upgraded? Sunder's remark on the shock, well, look into that as well as the stab. shock. So, this does only do this when driving slow? Still wondering about that. Mine used to make noises, but not the rattling/grinding noise you mention. Less than that, and was tire rub. At first, it was only on one side until I put the drop pitman arm on, had the steering and wheels aligned, now does it on both sides and today I am adjusting the bump stops to eliminate that. The noise it makes is the rubber on steel vibration sound at full turn left or right.... With that, the springs were rattling a little making a more metalic noise. Doesn't do it unless at or near a full turn of the wheels. Good luck and let us know what you find!
Re: symptoms..
[Re: NCBBA2358]
#571001
03/04/05 10:49 PM
alright boys, havent driven jeep for a while mainly my civic... but the symptoms have gotten worse now it seams to be on both left and right turns and kinda feels like its galloping even when going straight now, and sometimes when i first start goin like after just starting it u in the mourning there is a loud screatching noice like metaljust rubbing metal or a sumiliar symptom would be a bad idler tensioner pulley. i am hopeing its just a $20 u-joint.. any help would be appriciated.... and as for my shox they seam fine tho old but not the source also keep in mind that i have yet to have this problem and hope to learn from it so im able to do it on a trail.. so i wouldnt be the best to get up under and exactly know if a U-Joint is bad... detail on that would be great  ~Reign
Re: symptoms..
[Re: Reign]
#571002
03/04/05 11:37 PM
Reign To check a u-joint put the parking brake on and OUT of gear get under it and shake and push and pull with all you have on both ends of the driveshaft.. ANY movement or "slop" in the joint is BAD! If one on a shaft is bad do em both.. The other thing to look at is to jack up one wheel at a time and turn it by hand and shake it by hand listening for the bearing to make the noise. If the noise is in the rear you can put stands under both sides and start and let her idle in gear while listening to the different parts. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: symptoms..
[Re: BigJim]
#571003
03/05/05 02:23 AM
I had the same sound only I called it a clunk. what it turned out to be was 4 loose bolts on my tranny mount.
It felt like it was coming from the passenger side drove me crazy for months.
hope this helps.
other sugg would be to check the track arm bushings.
hey it how i got the name clunkedout.
