rear axle swap question #571454 02/21/05 04:03 AM
kjishikawa Offline OP
I want to swap the wider rear axle into my '85 runner and was wondering about the parking brake cable. Is there enough play in it for the extra 3 inches or do I need to swap that over from the donor vehicle also? Thanks.
Re: rear axle swap question [Re: kjishikawa] #571455 02/21/05 04:17 AM
4Crawler Offline
I think you either need the on-axle cable or make extensions for the existing one, which is what I'll be doing since I did not get the cables with my wider rear housing.
Re: rear axle swap question [Re: 4Crawler] #571456 02/21/05 05:27 AM
matts Offline
Roger, I thought you would have been an "early adopter" on the wide axle swap <img src="/forums/images/graemlins/wink.gif" alt="" /> Are you going to use the IFS hub widening trick on your front? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: rear axle swap question [Re: matts] #571457 02/21/05 05:54 AM
4Crawler Offline
I've had the wider housing for a few years now, just have not had the time to get it installed. My front axle is already wider, so the rear will match it.
Re: rear axle swap question [Re: 4Crawler] #571458 02/21/05 11:30 PM
matts Offline
So what route did you take to widening your front axle? I don't see anything on that on your 4crawler website. -- Matt
Re: rear axle swap question [Re: matts] #571459 02/21/05 11:56 PM
4Crawler Offline
Hybrid axle, ~3" wider than stock:
Re: rear axle swap question [Re: 4Crawler] #571460 02/22/05 07:39 AM
matts Offline
Looks like AllPro's D60 knuckle job. They advertise 62", a gain of 6-1/2" over stock. How'd you keep it to 3"? -- Matt
Re: rear axle swap question [Re: matts] #571461 02/22/05 05:02 PM
4Crawler Offline
I've never measured mine, but it seems to be 58"-59" wide, which is what they originally advertised the width to be (i.e. that of a rear IFS axle) and short of extending the stock axle "tubes" that is about the limit of what you can get by swapping knuckles on a stock axle housing as far as I can see.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6274 MB (Peak: 0.7257 MB) Data Comp: Off Server Time: 2026-06-17 04:07:50 UTC
