Front leaf spring replacement recommendations for a daily driver? #572642 02/23/05 07:07 PM
Buster Offline OP
The front springs on my '85 DD are pretty shot. What brand of stock height springs would you guys recommend for a daily driver? Thanks. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Front leaf spring replacement recommendations for a daily driver? [Re: Buster] #572643 02/23/05 07:12 PM
4Crawler Offline
Probably the best setup is the OME 2" lift springs/shocks. While they are a lift spring, you can hardly tell there is any lift. This '85 has the OME kit and 31s:
Re: Front leaf spring replacement recommendations for a daily driver? [Re: Buster] #572644 02/23/05 10:15 PM
superv43 Offline
I have the OME leaf springs both front and rear on my 85 pickup.
Pros:
- Completely bolt in. No welding or changing of spring mounts required.
- Safe to use with the stock push-pull steering and torque rod.
- Much improved ride over stock.
Cons:
- Rear is way too stiff in my truck and is still 4-5" lifted over stock, even after a year of settling.
- Fairly expensive.
For a daily driver, the front OME springs are great. The rear just seems too stiff overall. It does ride great with about 900lbs of wood in it.
I am probably going to take the next step and go longer springs in the rear for better ride and flex.
A picture of my truck with the OME spings on for about a year:
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5948 MB (Peak: 0.6485 MB) Data Comp: Off Server Time: 2026-07-13 15:48:51 UTC
