First the usual caveats: I freely admit I have no idea what I'm doing and that I'm in over my head. The only other serious wrenching I've done was a ball joint and CV boot replacement (some may remember a post or two from me about that,) and there were a whole lot less moving parts involved. I have a Haynes manual and more enthusiasm than brains.
Next, the back story: the Rodeo was leaking some oil (not a lot, but it wasn't leaking any before I put lighter oil in hoping to help with the ticking) and some coolant (and the green puddles in the garage seemed to be getting bigger.) So I decided to take a crack at hunting down the leak, and changing the radiator hoses. So far so good.
Then along comes the well intentioned co-worker who once rebuilt a 70 Gremlin or something equally hideous (and simple) who said "Really you should change the belts too, and if you do the timing belt, the water pump isn't that hard to get to, and if you are going to do all that, you might as well change the valve covers - I bet it would help the leaking. And if you are going to take the valve covers off, might as well do the spark plugs. And gee, since you are THAT far in, you might as well change the head gaskets too." ...Anyone see where this is going?
So I started taking things apart this weekend, and actually made relatively good progress Sunday. Actually I say "good progress" like I would know it if I saw it. Let me rephrase - I think I can put back together what I have disassembled so far. I have the air intake hose off, the EGR and throttle body off, the air intake plenum off, the radiator hoses off, the radiator out (it was only two screws once the hoses were off, and opened things up in there), the fan out, all the belts off (including the timing belt) and the water pump out.
Tonite was a different story. I started trying to get the valve covers off, and after spending a disgustingly long time fiddling with hard to get to cover bolts, I now have the thing completely un-bolted. I was hoping at this point, I could gently pick up the cover, and voila! No such luck. The manual suggests whacking the cover with a hammer and a piece of wood. Tried that with several variations on the theme. The next suggestion is to take a flexible putty knife and start working it into the seal.
Something tells me there HAS to be an easier way, and I'm a little hesitant to start going at it with a putty knife. Once I start digging away at the thing, I'm pretty sure I will have crossed the line where I can no longer just put it all back like I found it and pretend this never happened. Of course, if I do that, the leaks around the valve covers will remain, I'll obviously not be able to get to the heads (that might not be a bad thing) and I'll have to face my own personal failure and live with my damaged ego for at least a day or two before I forget about it.
So my questions are:
1) Is there an easier way to get the valve covers off other than the flexible putty knife?
2) Is it worth messing with the heads (regardless of the valve covers) Is there something I should look for to determine this? (Oil in the spark plugs?)
3) Any thing else anyone can think of I'm missing?
I HAVE been taking a lot of pictures as I go, and hope to have a decent write up to share with the group when I am done, so with luck even if my own personal experience comes up a boondoggle, maybe others can learn from my ineptitude.
Here's some photos of where I am right now:
The engine in it's current state.
![[Linked Image]](http://www.vaughnnet.com/Gallery/2005-02-27_Rodeo_Engine_Rebuild/IMG_5290.JPG)
One of the two immovable valve covers.
![[Linked Image]](http://www.vaughnnet.com/Gallery/2005-02-27_Rodeo_Engine_Rebuild/IMG_5284.JPG)
