2000 Trooper Tranny noise in L (4l30) #575300 03/02/05 04:13 PM
Sfinx Offline OP
My 2000 Trooper with auto tranny make funny noise when switched to firs gear (L). I donÆt know what it is, but during normal operation it works good without any noises, only when switched to L and decelerating I can hear metallic noise, almost like fast spinning disc hitting a shroud or some kind of guard. Unfortunately, I was unsuccessful with my search, hope someone can help. <img src="/forums/images/graemlins/confused.gif" alt="" />
The mighty oak tree was once a little nut that held its ground.
2000 Trooper LS with TOD
ARB bumper, custom roof rack, 33" BFGoodrich AT, K&N, OME springs, Aisin hubs, Rancho 9000, WARN XD9000, Maxi-Kool Tranny Cooler, Optima Red,
Re: 2000 Trooper Tranny noise in L (4l30) [Re: Sfinx] #575301 03/02/05 06:05 PM
A
Amigo-2k Offline
check the tranny fluid level and color
Re: 2000 Trooper Tranny noise in L (4l30) [Re: Amigo-2k] #575302 03/02/05 06:20 PM
Sfinx Offline OP
Fluid level is correct and fluid is brand new < 1000 miles.
I don't think it is related to recent fluid change, as I had that problem in the past right after tranny change, but it was fixed by the dealer.
Re: 2000 Trooper Tranny noise in L (4l30) [Re: Sfinx] #575303 03/03/05 09:08 AM
Bansil Offline
Ours had a similar noise so it could possibly be a heat sheid on your exhaust?Maybe the lower tones are vibrating a sheild........a hose clamp might fix the problem if that's it.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6010 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-05-30 01:07:06 UTC
