need some 3.0 idle help please #575714 03/03/05 07:05 AM
AlaskaToy Offline OP
In the last couple days I noticed at a stop sign, my Rpms were staying at about 1500-2000 rpm for several seconds (like 10 or more) before the idle would drop down to 900-1000 like normal. It is still doing it and its getting on my nerves. Looking at the throttel linkage, there appear to be a couple of little doohickies that have a plunger that extends, following the linkage when the throttle is pressed. When released, these plungers seem to slow the return of the linkage to it mechanical stop. The front plunger doohickie retracts very slowly, so I'm wondering is it is defective. Anyone else have this happen? I need soem help,, Thanks.
AJ
93 Toyota, dana 60, 14-bolt
Re: need some 3.0 idle help please [Re: AlaskaToy] #575715 03/03/05 07:19 AM
Toy Story Offline
Hey AJ. It's called a dashpot and it keeps the throttle from snapping closed too quickly. It's just a bellows that dampens the air passing through it. On the 22RE's theres a filter that can become clogged and cause it to hang. Not sure about the 3.0, but something to check.
85 Toyota SR5 Xtra Cab P/U
Re: need some 3.0 idle help please [Re: Toy Story] #575716 03/03/05 07:24 AM
Thanks! I'll take it ff tomorrow and see if I can clean it up some to see if it makes any difference.
Funny how many different boards you run into people you know from other boards <img src="/forums/images/graemlins/cheers.gif" alt="" />
AJ
Re: need some 3.0 idle help please [Re: AlaskaToy] #575717 03/03/05 07:29 AM
kewlynx Offline
I got Frankenyota's brother a sponsor thru this board when he got diverted out of tech school. Frankenyota was in Iceland! <img src="/forums/images/graemlins/cheers.gif" alt="" /> I see some of you guys in Moose Creek once in awhile.
**ubi apis- ibi salus**
Re: need some 3.0 idle help please [Re: kewlynx] #575718 03/03/05 10:05 AM
toyota4x4 Offline
Mine did that when the TPS went bad. Good luck with finding the problem.
89 Toyota pickup, 4x4, 5spd, 3.0V6
31x10.5 bfg's on 15x8 pacer rims
custom exhaust, k&n air filter
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6061 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-11-17 11:22:20 UTC
