Re: Ignition Switch Troubles [Re: garym] #577160 03/31/05 11:56 PM
rmg Offline
JM
Did you figure out your ignition problem yet? I have similar problems from time to time and didn't know if you had become an expert like garym suggested.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Ignition Switch Troubles [Re: rmg] #577161 04/01/05 05:39 AM
W
Winkel1 Offline
Take the switch apart, tear out the tumblers, put it back together. You can start it with a screwdriver then(but still use your key), but no one will know. I know it sounds kind of cheesy, but no more tumbler trouble, and cheap to do.
98 T100 SR5 4WD
Rhino Liner
Warn Hubs
Mostly Stock
Re: Ignition Switch Troubles [Re: rmg] #577162 04/01/05 09:25 PM
JM
Not really. I ended up taking the switch out and apart, cleaning everything, and putting it all back. The problem still persists but I am just "dealing" with it for now.
Winkel1's suggestion is sounding pretty good right about now <img src="/forums/images/graemlins/wink.gif" alt="" />
jm
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5938 MB (Peak: 0.6649 MB) Data Comp: Off Server Time: 2026-10-24 01:15:13 UTC
